  • July 05, 2025, 06:15:33 AM
Author Topic: More wing construction  (Read 1123 times)
Offline Curare
« on: February 21, 2013, 12:22:09 AM »
Dave, that wing looks interesting.. I take it's foam core, sheeted and then cut out between the ribs?
Nice!
« Last Edit: February 21, 2013, 05:14:29 PM by Paul Taylor »
Greg Kowalski
AUS 36694
Offline ray copeland
Re: What's on your build table or paint stand?
« Reply #1 on: February 21, 2013, 07:30:43 AM »
Dave, will there be adjustable leadouts? If so, could you do a picture, i need some fresh ideas for my chipmunk.
Offline Dave Denison
« Reply #2 on: February 21, 2013, 11:13:09 AM »
Hi Ray
I was able to incorporate the standard Adjuster in the wing tip.  The inside block is maple, with 1/32 ply outer doubler. The picture tells all....enjoy.   Hope this has helped.
ama41041
ama 41041
