  • June 19, 2025, 01:24:17 AM
Author Topic: Ringmaster Jr. wingtip weight  (Read 1458 times)
Offline Dave Nyce
  • Flying
    • Revolution Sensor Company
« on: July 17, 2013, 07:47:14 AM »
Rebuilding an old Ringmaster Jr.  How much wingtip weight is needed?  Planning to use a McCoy Redhead .19, is that the correct size engine?
Dave Nyce   New Bern, NC
AMA: L356
Re: Ringmaster Jr. wingtip weight
« Reply #1 on: July 17, 2013, 08:13:21 AM »
I think 3/4 ounce should do the trick.  A lot depends on the line sizes and if all the heavy ribs were put in  the out board wing.
« Reply #2 on: July 17, 2013, 02:56:34 PM »
Hi Dave,
I agree with Doc, 3/4 oz. will probably do.  I used a McCoy .19 Red Head on mine back around 1964.  It did a good job!  Just remember the oil needs of the Red Head, it needs more castor than the available R/C fuels.  Randy Smith has a great write up fuel for stunt engines at the top of the page under Engine Set Up section.
I hope all is well, it has been a couple years, (maybe more!) since we last got together.  I seem to be getting stronger from the cancer treatments so I will need to get back out flying!
« Reply #3 on: July 17, 2013, 03:47:09 PM »
How much wingtip weight?  Whatever is necessary.
Wait, what should I make the wingtip weight, then?  Adjustable.
(Yes, I am picky.  But weight boxes are easy and fun).
Make the leadouts adjustable too, if it's not too late.
Offline Bootlegger
« Reply #4 on: July 17, 2013, 05:16:38 PM »
  I have an OS Pet .099 on one and i it flies very well, without fuel it weighs 16 oz, and I fly it on .012 cables about 45' long, gonna make some longer lines.  (52') And try them, but I like the way it flies, keep us posted on yours, oh, the pet .099 likes a lot of castor.  22% castor and 5% syn...
8th Air Force Veteran
Gil Causey
AMA# 6964
