Building Tips and technical articles. => Building techniques => Topic started by: Dave Nyce on July 17, 2013, 07:47:14 AM
Rebuilding an old Ringmaster Jr. How much wingtip weight is needed? Planning to use a McCoy Redhead .19, is that the correct size engine?
I think 3/4 ounce should do the trick. A lot depends on the line sizes and if all the heavy ribs were put in the out board wing.
Hi Dave,
I agree with Doc, 3/4 oz. will probably do. I used a McCoy .19 Red Head on mine back around 1964. It did a good job! Just remember the oil needs of the Red Head, it needs more castor than the available R/C fuels. Randy Smith has a great write up fuel for stunt engines at the top of the page under Engine Set Up section.
I hope all is well, it has been a couple years, (maybe more!) since we last got together. I seem to be getting stronger from the cancer treatments so I will need to get back out flying!
How much wingtip weight? Whatever is necessary.
Wait, what should I make the wingtip weight, then? Adjustable.
(Yes, I am picky. But weight boxes are easy and fun).
Make the leadouts adjustable too, if it's not too late.
I have an OS Pet .099 on one and i it flies very well, without fuel it weighs 16 oz, and I fly it on .012 cables about 45' long, gonna make some longer lines. (52') And try them, but I like the way it flies, keep us posted on yours, oh, the pet .099 likes a lot of castor. 22% castor and 5% syn...
