  • June 19, 2025, 06:09:39 PM
Author Topic: Jigs From Control Line Central  (Read 4557 times)
Offline Dick Pacini
« on: December 28, 2009, 03:29:05 PM »
Today I received my fuselage and wing jigs along with the set of V-blocks.
I was totally impressed with the quality and workmanship of these jigs, even down to the packaging.
I have been involved in manufacturing almost all my working life and I owned a small manufacturing company for 21 years.  These jigs are as good as you could ever want and the price is absolutely on target.
A big thumbs up! CLP** CLP** CLP**
AMA 62221
Re: Jigs From Control Line Central
« Reply #1 on: December 28, 2009, 08:50:21 PM »
Would I be correct in asuming they are available again then? I know for a time he was not able to keep up with demand since they were so popular..
Offline Dick Pacini
« Reply #2 on: December 28, 2009, 09:29:04 PM »
He just finished another batch.
AMA 62221
« Reply #3 on: December 30, 2009, 08:38:10 PM »
Any chance for a closeup photo of a few of the legs and other bits?   #^ Steve
Offline Dick Pacini
« Reply #4 on: December 30, 2009, 09:12:02 PM »
Scroll down and click the pix.
http://www.clcentral.com/products.asp?cat=44
AMA 62221
Offline Balsa Butcher
  • High Desert Flier
« Reply #5 on: December 30, 2009, 09:17:36 PM »
If you can find some of the pics of Walter Umland building the wings of his prototype kits you will see the CLC jig in action. I give it two thumbs up.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #6 on: December 30, 2009, 09:20:26 PM »
My jig is essentially the same. It works fine.
Offline builditright
  • So happy to be alive!
« Reply #7 on: February 01, 2010, 09:46:50 AM »
Thank you and God Bless
Walter
aka/ builditright
« Reply #8 on: February 06, 2010, 11:08:36 AM »
Thanks for the recommendation.  I got the jig and V blocks.  They look very nice.
Offline Bill Gruby
« Reply #9 on: February 13, 2010, 06:02:58 AM »
 I have been Jig building wings on 3/8 rods for years. Do you guys think the system you are using is better and why? Please don't mind the mess, Mama is moving things around upstairs and the overflow is comming down here.  LOL
  "Billy G"
Bill Gruby
AMA 94433
MECA 5393-10
Offline Allan Perret
  • Proverbs
« Reply #10 on: February 13, 2010, 11:41:42 AM »
  "Billy G"
I prefer the Morris style because:
Easier to build the jig itself.
References off of the LE & TE which is a greater spacing than the 2 rods,  any error in the rods is amplified out to the edges.
Does not require accurately cut holes in ribs, of course this is negated if you get your ribs laser cut.
Better support of the LE which allows stacking of heavy weights when gluing down the LE sheeting.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #11 on: February 15, 2010, 08:25:29 PM »
Due mostly to this thread, I went and dinged the plastic for the wing jig and LE V-blocks. I also popped for the Tom Morris (wooden) fuselage jig uprights. I got a confirmation of the order, and nothing about backorders, so I guess I'm good to go in a few daze (a Shultzie-ism).
Now, if I can just get one of those pinkslip things from work... y1 Steve
« Reply #12 on: February 15, 2010, 08:27:51 PM »
after having another slight warp in the latest wing- I also sprung for the wing jig and V-blocks....... something has to work !!!  hopefully this is it.
Offline Martin Quartim
    • StuntHobby
« Reply #13 on: February 16, 2010, 05:25:07 PM »
What I like the most about my wing jig is that I can do the top and bottom sheeting with the wing attached to the jig.  Almost impossible to get a wing warped. My friends are using it and loving it.
Martin
    • StuntHobby
« Reply #14 on: February 18, 2010, 01:39:55 PM »
Hi Ty,
I designed it and made a few sets at a local machine shop and sold them for $240,00. Now I don't have any but if there was a big interest I could make another batch and possibly reduce the cost.
You have no idea how much thought and how many drawings it took to make this simple and obvious design :)
I am also designing a new one that uses the same basic idea but using a lot less aluminum.
This wing jig could also work with rectangular LE spars, just flip the bar to use the flat side.
Martin
    • StuntHobby
« Reply #15 on: February 19, 2010, 07:40:04 AM »
Thank you for the kind an encoraging coments Ty.
I will look into making another batch and will check the cost delivered to US.
Martin
