  • August 01, 2025, 10:01:46 PM
Author Topic: I-beam derivative  (Read 1902 times)
Offline Jim Thomerson
I-beam derivative
« on: September 30, 2006, 06:08:08 AM »
I have built a couple of I-beamers except that instead of an I-beam, I used the same amount of wood to build a box spar tapered both ways.  I think it was much more rigid and stronger than a comparable I-beam.  I really like the I-beam and similar building methods.  Lots of fun.
Re: I-beam derivative
« Reply #1 on: September 30, 2006, 10:12:54 AM »
Hi Jim,
The "box" beam is a great idea and is stronger.  I haven't done one that way "yet", as I wasn't sure I could get it as light as a solid piece of wood when counting in the glue....... ???
The solid piece of 1/4" in a regular size I-Beam is plenty strong enough, but I do know the box would be even stronger and more twist resistant..  y1
Bill <><
Offline Bill Sawyer
« Reply #2 on: September 30, 2006, 10:39:23 PM »
BOX BEAM ? Where have I heard that before? Oh yes, the Playboy kits have them! Much stronger and not much heavier. And they come prebuilt in the kits.
Bill Sawyer
AMA 53987
Windancer Models
« Reply #3 on: October 02, 2006, 02:55:36 PM »
look up the plans for the Moody Mooney.  Very innovative, with a thick wing and a huge box beam out of 1/16 in. balsa.  More work than I could imagine when I was a kid.
« Reply #4 on: October 06, 2006, 10:39:49 AM »
Most of my planes are modified I-Beams. They have I-Beams that are actually built, a piece at a time, into the wing after the ribs are installed. It's a sort of Warren Truss based I-Beam. Some have partial sheeting, some not. It's an interesting process.
Offline Warren Wagner
  • Bradenton, FL
« Reply #5 on: October 06, 2006, 04:03:51 PM »
Phil,
Though the "Mooney" looks like an extremely interesting project, that "box spar" construction looks daunting to me, and I'm not a kid.
The small plans are difficult to read, so actual construction of the "box spar" is not clear.   Perhaps a full scale plan would make it obvious, but it looks like a very tricky build, that would require extreme care and workmanship.
Wouldn't it be interesting to get Al Rabe's opinion on just how viable a stunt ship the "Mooney" would make.   It certainly would be unique, and not easily confused with any other design.
Cheers.
Warren Wagner
Warren Wagner
AMA 1385
