  • August 02, 2025, 05:57:44 AM
Author Topic: i beam construction  (Read 1921 times)
Offline mark eisenhut
    • madphotos.net
i beam construction
« on: January 18, 2007, 05:45:10 AM »
 what makes an i beamer an  i beamer? i know this is a dumb question but had to ask because i guess i don't know .
thank you
mark
mark eisenhut
Re: i beam construction
« Reply #1 on: January 18, 2007, 06:27:30 AM »
thank you
mark
The spar has the shape of an I-Beam, and the ribs are just "strips" that attach to the LE, spar, and TE.  Usually the riba are 1/8th" wide and 1/4" deep.
    • madphotos.net
« Reply #2 on: January 18, 2007, 06:51:37 AM »
so there is relay no ribs just cap strips from the le notched in the spar to the te.
thank you
mark
mark eisenhut
« Reply #3 on: January 18, 2007, 07:21:34 AM »
thank you
mark
Hi Mark,
In traditional I-Beam construction, the "caps" of the I-Beam are shaped down to allow the underside of the ribs to glue flush to them.  No "notching" of the ribs.  A sharp corner causes stress risers as you know.  ;D
I have found it somewhat amusing that some think that the slot for the LOs that most I-Beam spars have is cause for alarm.  A few people even go so far as to replace the spar caps with plywood.  This is just a little ridiculous, IMHO.  I do like to face the inside of the TE, and also sandwich between the caps and spar, a piece of .007 strip CF.  The rear support spar is also often left out on the smaller I-Beamers, being replaced with "uprights" to keep the ribs from collapsing. On a plane such as the USA-1 however, that 1/16th' rear support spar is necessary.  Even "X" bracing between the ribs will not lend enough support.
Built as designed, and covered correctly, an I-beam ship is very durable.
Bill <><
    • madphotos.net
« Reply #4 on: January 19, 2007, 07:35:49 AM »
thanks bill
would you have any  pictures i think i understand  just cant picture it in my head
thanks again
mark
mark eisenhut
« Reply #5 on: January 19, 2007, 07:44:22 AM »
When I get home today, (or this weekend) if no one else has posted some pictures, I will take some.  Good ol' *LIFE* gets in the way, sometimes, of what we would REALLY like to do! :D
Good thing is, work is going great today!  (better not jinx it!)
Bill <><
