  • August 01, 2025, 09:38:14 AM
Author Topic: Removeable flaps  (Read 2371 times)
Offline Leester
Removeable flaps
« on: September 30, 2006, 04:07:43 PM »
At one of our Mt. Joy flying sessions Crist R. showed me how he uses 1 pc of .025??  wire to connect the hinges on each wing panel. I forget how this was secured to the wing and is the horn wire then held in only by the horn bearing? and the hinges being connected?? Removeable flaps is something I haven't done but want to do with my planes from now on.   Thanks
Leester
ama 830538
Online Crist Rigotti
Re: Removeable flaps
« Reply #1 on: September 30, 2006, 06:02:08 PM »
Lee,
The flap or elevator horn is held in place using a brass tube and glued into the fuselage.  the flpas or elevator has a brass tube to accept the horn wire.  Use Klett hinges and .025 wire.  Bend the end of the wire 90 degrees and use a SIG 1/32 eyelet in the TE.  Insert the 90 degree bend into the eyelet to secure the wire.
Offline Leester
« Reply #2 on: September 30, 2006, 06:12:46 PM »
Thanks Crist, I was missing the tube in the fusalage part. It all makes sense now.
Leester
ama 830538
Offline Ralph Wenzel (d)
« Reply #3 on: September 30, 2006, 06:16:32 PM »
Hi Crist, et al.,
And this method, using Klett hinges, will no longer be an option when current stocks are used up. I called the Klett Plastics factory in Ft. Worth on Thursday, Sept. 28, , and got the following (somewhat paraphrased) message, "Thank you for calling. Due to the death of the owner, Klett Plastics has closed its doors, and will no longer be taking orders".
I had called to order a bunch, as the Klett's were the only nylon hinge I've ever used successfully. I suppose I could cut the head off the pin of a DuBro hinge . . .
Ralph Wenzel
AMA 495785 League City, TX
Offline Leester
« Reply #4 on: October 01, 2006, 11:14:21 AM »
I did forget one thing, how do you recess the hinges?? or don't you.
Leester
ama 830538
« Reply #5 on: October 01, 2006, 01:00:10 PM »
See the thread on hinge pockets.
Offline Leester
« Reply #6 on: October 01, 2006, 01:51:27 PM »
Crist: I know how to recess the hinges but with the wire going the full length of the flap or elevator how does the wire pass through the wood between the hinges???
Leester
ama 830538
« Reply #7 on: October 01, 2006, 02:30:53 PM »
It doesn't.  It stays in between the TE of the wing and the LE of the flap.
« Reply #8 on: October 01, 2006, 02:40:25 PM »
Here's a picture of my Harbinger at the wing tip.  You canb see the eyelet, hinge pockets and the hinge wire.
Offline Leester
« Reply #9 on: October 01, 2006, 02:48:40 PM »
Thanks Crist much appreciated.
Leester
ama 830538
Offline Glen Wearden
« Reply #10 on: October 01, 2006, 06:43:25 PM »
It appears that this method leaves quite a gap along the hinge line.  Do you seal it with tape, or does the pin itself close the gap enough to suffice?     Glen
Glen Wearden
« Reply #11 on: October 01, 2006, 07:40:02 PM »
I always seal all my surfaces with sealing tape.
Online RC Storick
« Reply #12 on: October 01, 2006, 07:57:13 PM »
Just ask me I know!  **)
« Reply #13 on: October 01, 2006, 09:00:29 PM »
Bob knows that I seal all my hinge gaps, trust me.
