  • June 17, 2025, 07:44:39 AM
Author Topic: how to fix hole in wing?  (Read 1816 times)
Offline frank carlisle
« on: May 03, 2007, 06:31:28 PM »
How would you fix this?
Frank Carlisle
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: how to fix hole in wing?
« Reply #1 on: May 03, 2007, 07:13:31 PM »
hmmmmm...I don't suppose, at this point, a piece of scotch tape would do, huh?  (Just kidding).
How'd you do that?
--Ray
AMA902472
« Reply #2 on: May 03, 2007, 07:17:39 PM »
Scotch tape?? That's a thought Ray, but I'm going to hold out for a while. Maybe something better will come along.
I did that when I was pulling off the stencil. Cool huh? HB~>
Frank Carlisle
    • Minnesotamodeler
« Reply #3 on: May 03, 2007, 07:25:48 PM »
Yeah, bummer.  How'd you do the two-tone lettering?  Pretty neat.
--Ray
--Ray
AMA902472
« Reply #4 on: May 03, 2007, 07:35:28 PM »
I painted the orange first and then masked an inch top and bottom and sprayed the center red.
I'm pretty pleased with the results except for that dang hole.
I'm sure whatever it takes to fix it will be hard to do. y1
AND-----It still won't fit in my truck!!
Frank Carlisle
    • Minnesotamodeler
« Reply #5 on: May 03, 2007, 07:45:38 PM »
Frank,
I just had a revelation--if you chop the wings off just outside the engines, it should fit in your truck fine.
All these months of worrying, and such a simple solution!!!
--Ray
--Ray
AMA902472
Offline Leester
« Reply #6 on: May 03, 2007, 07:53:20 PM »
Frank: I've seen Windy build up spots he had sanded through with rejuvinator. If you can pull the covering up with a pin or knife blade tip you could add as many coats a necessary and then sand smooth and touch up. Better than tape ?
Leester
ama 830538
« Reply #7 on: May 03, 2007, 07:59:21 PM »
Way better than tape Lee. Thaanks. As you can see Ray just wants to chop the wings off. I like your solution better. Although Ray's fix would also have the plane fitting in my truck.
Frank Carlisle
« Reply #8 on: May 04, 2007, 06:19:45 AM »
Hey Leester------I used clear dope (thick) and pushed it into and over the hole. It fixed it just fine. By this morning the dope was shrunk and the surface was ready for a dash of white touch up. All in all not a bad fix.
Frank Carlisle
« Reply #9 on: May 04, 2007, 07:28:26 AM »
The small hole repair looks good Frank,
But it did not solve the real problem.
I think Ray was on to something.
« Reply #10 on: May 04, 2007, 09:23:42 AM »
Frank,
For small holes like this, I will often just dribble a little CA on it and smooth with my finger. Let it go off then sand lightly, dab on a bit of fillercoat, sand and repaint. Seems your method worked fine, though.
Offline Leester
« Reply #11 on: May 05, 2007, 09:31:49 PM »
Frank: I'm happy that you got it fixed, now you can sleep better or dream about your R/C babe.  LL~ LL~ LL~ LL~
Leester
ama 830538
« Reply #12 on: May 06, 2007, 04:16:00 AM »
Yeah getting it fixed was a good thing..........BTW..my r/c babe (Roxanne) has converted to c/l. We have a circle out back and she is prego. I'm now getting a solid 8 hours of sleep a night.
Frank Carlisle
