  • June 17, 2025, 07:46:01 AM
Author Topic: A couple more "Sequal" pix.  (Read 1016 times)
Offline Ted Winterman
« on: May 06, 2007, 06:26:40 PM »
    Another view and a close-up of the front end. This is my tank securing method. Its easy to
get in and out for what-ever reason you may have. Tank is very secure. Use of J-bolts and
rubber bands is all that is needed. I use blue building foam shims to take up left over space. The
foam adds '0' weight. Check rubber bands once-in a while before flying.
