Thanks Bob Reeves I'll give it a try.
I went back and re-did the fillets where they go around the leading edge of the wing. I used a marble CA'd to a stick so I would have something to hold onto. They came out really sweet. Thanks Bob.
I found that it's not a good idea to use the marble when you have a bunch of material to push around, but if you use the marble after you've done 90 percent of the shaping it works really nice. Thanks again!!!. SWEET, SWEET, SWEET
