  • July 09, 2025, 12:10:57 AM
Author Topic: Hawker Typhoon flap fairings  (Read 1030 times)
Offline Leester
« on: July 29, 2007, 11:14:33 AM »
I have the flap fairings temp in place, the plans don't show a shape of them in relation to the flaps which are tapered 3/8 to 1/8. Should I taper the fairings the same as the flaps ? or slightly larger ? TIA
Leester
ama 830538
Offline frank carlisle
Re: Hawker Typhoon flap fairings
« Reply #1 on: July 29, 2007, 12:34:14 PM »
That's nice woodwork you've done so far. I don't know how scale you want to get the fairings but I suspect that pretty would be sufficient. Probably I would center the fairings the way you've done in the picture then trace a line top and bottom from the flap and then shape to blend.
Frank Carlisle
Offline Leester
« Reply #2 on: July 29, 2007, 01:04:05 PM »
Thanks Frank: I just wanted to be sure before I did any cutting, sanding etc.
Leester
ama 830538
Offline Warren Wagner
  • Bradenton, FL
« Reply #3 on: July 31, 2007, 09:25:10 AM »
Leester,
  (I mistyped "Keester"....do you even get that?)     ;-)
By the quality of your woodwork, whatever YOU choose is going to be fine with me !!!
Very nice work.  Keep the photos coming.
Cheers.
Warren Wagner
Warren Wagner
AMA 1385
