  • June 19, 2025, 01:10:45 AM
Author Topic: Hangar 9 paint question  (Read 1283 times)
Offline Larry Renger
« on: June 23, 2008, 11:11:36 PM »
Being desperate to match the color of some UltraKote, I purchased a can of matching Hangar 9 paint.  I have heard negative reviews on this stuff and would like some more input before screwing up a perfectly good model.
1.  Is the stuff not adequately fuelproof for 10 -15% nitro as claimed?
2.  Is it so bad that it should be immediately taken to the toxic waste dump?
3.  What cautions should be used for the undercoating, I was planning to put it over a Nitrate Dope base.
4.  Without going into 2-part systems is there an alternative to matching Flame Red Ultrakote?
HELP!!!!!   ???
Offline RC Storick
Re: Hangar 9 paint question
« Reply #1 on: June 24, 2008, 06:05:49 AM »
What you could do is take the monokote to a auto paint store.Have them shoot a profit on it to match it perfectly. Then have them make you a spray can of single stage Auto Urethane.
Offline Jim Oliver
« Reply #2 on: June 24, 2008, 07:06:13 AM »
Larry,
I gave up on the Ultracote paint---it took days to almost dry and wasn't even close to being fuel resistant, much less fuel proof.
I think you will find Top Flite Lustercoat paint much better stuff.  The Lustercoat Missle Red is a very close match to UltraCote Flame Red----not perfect, but very close.  I mixed some Sig Light Red and some Sig Lemon Yellow dope to match the Ultracote Flame Red, but the Lustercote works very well.
Cheers,
Jim
Edit to add:  No intent to bash Horizon products; I like Ultracote covering much better than Monocote covering......
« Last Edit: June 24, 2008, 02:04:30 PM by Jim Oliver »
Jim Oliver
AMA 18475
« Reply #3 on: June 24, 2008, 07:24:13 AM »
I am not familiar with the term "profit" as applied to paint.  What does it mean?
Offline RC Storick
« Reply #4 on: June 24, 2008, 07:29:29 AM »
A profit is a machine they use to match colors. Auto paint drys in a hour.
Walter Hicks
« Reply #5 on: June 24, 2008, 07:00:46 PM »
Larry,
    I have done what Sparky suggested. Worked very well. Take your Monokote to Auto paint store. I use Omni
Base Coat Clear Coat system. Spray your colors then spray clear over the whole plane!
Purple,Yellow and White are paint on fuse of modified Score ,wing is Monokote .
