  • June 19, 2025, 11:39:25 AM
Author Topic: Formula 560  (Read 1001 times)
Offline Geoff Goodworth
Formula 560
« on: December 12, 2009, 08:20:14 PM »
G'day folks
Does anybody know if there is a solvent for Formula 560 Canopy Glue that will not damage balsa?
Thanks in advance, Geoff
Re: Formula 560
« Reply #1 on: December 14, 2009, 11:20:34 AM »
As far as I k now this stuff is pretty much impervious to everything accept maybe a prolonged soaking in castor oil (don't ask). On bare balsa I would think it would peal off fairly well. I'm assuming is a bead of glue holding a canopy of window in place. If you've laminated balsa with it, I think you're pretty much stuck with what you have. (no pun intended!)
Looking forward to other replies.
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Formula 560
« Reply #2 on: December 15, 2009, 12:49:11 AM »
It isn't waterproof and will soften if wet but not sure that helps.
