  • July 09, 2025, 05:39:35 PM
Author Topic: Foam wing covering problem.......  (Read 1883 times)
« on: July 13, 2010, 09:40:00 PM »
OK, I have a foam wing that is just covered with balsa on the LE, TE, and has geodesic cap strips.  I have considered using SLC from Phil since it will go on with low heat and is light, and I thought of doing like several here and coming back over it with "00" silkspan to apply a painted finish.
Any other answers to the problem?
TIA!
Big Bear
Re: Foam wing covering problem.......
« Reply #1 on: July 13, 2010, 11:20:01 PM »
waterbased Poly U???
if you used epoxy with the sheeting, you are good to go straight over that - then SLC on the open bays...
I use SLC on my foam wings  - works great.
« Reply #2 on: July 15, 2010, 08:02:48 AM »
Remember to buff the SLC with very fine paper.  It don't take much.   H^^
Offline Michael Boucher
« Reply #3 on: July 20, 2010, 11:06:06 AM »
Covered two foam wings with silkspan attached with 50/50 elmer glue applied with a foam bush. It turned out very nice.  :)!
AMA 59633
Offline sleepy gomez
« Reply #4 on: July 20, 2010, 02:58:52 PM »
Be sure to use unflavored gelatin with HOT water to seal the foam/silkspan.  One packet to one and one half ounce water.  This will seal out lacquer thinner!  Several coats of clear water base Polycrylic will also seal but will add more weight.  Then use any fuel proof  paint.
Offline ray copeland
« Reply #5 on: July 20, 2010, 05:22:58 PM »
Bill, this pic is of a foam wing from Phil covered with his SLC. The only thing i did prior to painting with Rustoleum  was a light coat of Duplicolor Adhesion Promoter. Twenty or so flights and 2 minor brushes with the ground and the paint is still looking good. Good luck with your project ,  Ray
« Reply #6 on: July 21, 2010, 11:36:45 AM »
Thanks for the comments, guys. ;D  In the past, I have covered all my foam wings in the traditional dope/silkspan way, but this one isn't fully sheeted, so......... ;D
I will get the SLC from Phil, and have at it! LL~
Thanks, again
Big Bear
« Reply #7 on: July 22, 2010, 08:06:43 AM »
Remember the shiny side is the outside surface.  Of course you will learn real quick when you kit it with he iron.   H^^
« Reply #8 on: July 23, 2010, 06:40:08 AM »
Thanks, Doc.  It is the same with polyspan!  I knew about the polyspan, but I'm glad you told me that about the SLC.  I'll remember that. (I hope! LOL!!)
Offline Alan Buck
« Reply #9 on: July 23, 2010, 04:13:16 PM »
HI, Bill I used slc on my Staris on the the open bays of the wing with no problems. Scuff it with sotch brite and dope it silkspan it no problems.
ALAN E BUCK
