  • July 09, 2025, 12:50:41 AM
Author Topic: Foam Cutting  (Read 6704 times)
Offline James Strickland
Foam Cutting
« on: May 03, 2013, 05:39:11 PM »
Hi All,
Can anyone please recommend to me what I can use to power a hot wire for foam cutting, other than buying the feather lite or whatever the one advertised in MA is called and is quite expensive? Any help is greatly appreciated.
                                  T.I.A.,
                                        James
Offline Crist Rigotti
Re: Foam Cutting
« Reply #1 on: May 03, 2013, 06:51:38 PM »
Google your question.  I'm sure you'll get lots of hits.
Re: Foam Cutting
« Reply #2 on: May 03, 2013, 06:58:30 PM »
I built one with a transformer and a rheostat.
Re: Foam Cutting
« Reply #3 on: May 03, 2013, 07:41:40 PM »
Hey Randy, which transformer and which rheo?  Thanks, James
Re: Foam Cutting
« Reply #4 on: May 03, 2013, 07:45:39 PM »
Hey Crist, Yeah, I always Google everything first, I didn't find diddley crap.  James
Offline Frank Sheridan
Re: Foam Cutting
« Reply #5 on: May 03, 2013, 07:51:39 PM »
Re: Foam Cutting
« Reply #6 on: May 03, 2013, 08:01:28 PM »
Will a model train transformer work?  James
Re: Foam Cutting
« Reply #7 on: May 03, 2013, 08:03:05 PM »
For my foam cutting system I built a heavy duty 13.8 power supply and use a DC POTENTIOMETER  to control the amount of current, you can also just buy one and a POTENTIOMETER, if you can get the Variac at a decent price that would be the way to go
You can also use a 12 volt car battery and a control potentiometer, I have even seen people use one with a small lawn battery/and charger  and a controller
Re: Foam Cutting
« Reply #8 on: May 03, 2013, 08:24:57 PM »
OK, so I have a 24v, 55a dc power supply, what do I need to go ask for/ buy to control the power to the cutting wire/ wire temp. to get the proper cut? I'm sorry, even though I was a copier tech. for 5 years, many of these terms are Greek to me. Thanks for all the help so far, anyway what do I need to go buy?   James
Offline PatRobinson
Re: Foam Cutting
« Reply #9 on: May 03, 2013, 08:36:59 PM »
Hi James,
For years I used one of the middle to larger Lionel model train transformers with .012 stainless flying line and a home made bow. A small train transformer won't work, I tried one. You might find a larger train unit cheap somewhere like craigs list or at a yard sale.
You mentioned the Feather Cut unit - warning you must use ONLY their iconel wire or you may damage the power supply. I have one and have not tried other wire. It is a nice unit and works but you have to fiddle with it an make test cuts like any other system. The main goal of the feathercut is to eliminate human error in cutting process.
Finally, the most flexible and capable power supply that also allows you to create your on hand cutting tools to make channel cuts and etc. is a  Variac Variable Transformer.  Mine has a fuse at the AC input and it is capable of delivering consistent temperature. Look online (or at a nearby electronics surplus store near you) for a  surplus used Variac if you want one.
A power supply needs to be variable enough to heat the wire to the right temperature -if the wire is too cold or too hot a poor cut can occur.
I have read some people use a constant source like a battery charger and attempt to control the temperature by changing the length of the wire leading to the bow. Well lots of luck with that because getting the temp right takes some testing to get right with a variable transformer so I don't even want to mess with a non-variable power supply. Let's just say they were better than me if they got it to work.
Check online for how to make a foam wing cutter power supply and I think you may find some RC sources telling how some people built their power supply.
Hope this helps and best wishes,
                                                            Pat Robinson
PS. While I was typing I just saw Randys reccomendation about a Variac and I concur and I would add that you may need to shop carefully - some variacs I saw online were pricey and others not as much.
Re: Foam Cutting
« Reply #10 on: May 03, 2013, 09:06:05 PM »
I use Nichome wire. I think I got it from Sig.
I went out and looked and mine's made from parts from Radio Shack. Transformer is conversion from 120V 60 to 12 volt and a potentiometer.
Pretty easy, actually.
Re: Foam Cutting
« Reply #11 on: May 03, 2013, 09:44:26 PM »
hey thanks Pat, & everyone,  I think my 24 VDC 55A pwr sply is plenty, now I just need to know what to buy (what kind of rheostat) to control the temp. of the wire? I think.   James
Offline sleepy gomez
Re: Foam Cutting
« Reply #12 on: May 03, 2013, 09:55:23 PM »
Go to the Barton site controlline.org.uk.  Search foam.  Scroll down to General - foam cutting.  Scroll down to post by Sleepy Gomez.  This is close to the Holy Grail for the non professional.
Re: Foam Cutting
« Reply #13 on: May 03, 2013, 10:43:00 PM »
Thanks Sleepy, got reg. with Barton and all, but MPI is just trying to sell me domain names from Go-Daddy.
Re: Foam Cutting
« Reply #14 on: May 04, 2013, 05:32:33 AM »
Probably the oddest thing I ever heard of was the use of an R/C transmitter and a fairly large ESC hooked up to a foam bow. They used the throttle lever to control the power to the bow.
I think their power source was a car battery.
Re: Foam Cutting
« Reply #15 on: May 04, 2013, 08:49:28 AM »
If it was one of the old brushed-motor ESCs it should actually work pretty well -- those things just turn the battery on and off really fast, with a variable ratio between on and off.  That's exactly what you'd want if you had a DC supply and you wanted to drive the wire.
Re: Foam Cutting
« Reply #16 on: May 04, 2013, 12:37:46 PM »
A Variac makes a good power supply.  Just make sure that it is wired properly.  Use a voltmeter and make sure that the two lines in the outlet have one at ground potential(reads near zero with respect to a good ground) and doesn't change with the dial)  the other power wire should go to ground when the dial is at zero and track up with the dial.  It is quite possible to wire up a Variac with 110v. on one wire and a variable voltage on the other.  Not safe at all, and don't trust the manufacturer, since in many applications it doesn't matter.
A standard light dimmer also works OK.  Wire a 200 watt lightbulb to it and use the other end of the bulb to the wire, and the ground wire on the dimmer to the other end of the wire.  Again, use a voltmeter and make sure that 110 v.does not appear on either of the connections to the wire.  The bulb makes a nice space heater in the winter, and acts as a fuse if the wire accidentally gets shorted out.
For either one, make sure the wall outlet is protected by a GFI(ground fault interrupter) socket.
For cutting wire .012-.018 flying line, either solid or stranded works fine.  Nichrome stretches a lot more.  I bought a couple of miles of .010 Inconel quite a few years ago.  It outlasts anything and doesn't stretch much, only about 1/4in.on a 36 in. wire.  The downside is it requires more voltage, about 40v +- for a 36 in. wire.  24 v works OK if you don't rush the cutting speed.  I use a fixed, 24 v transformer for blocks and trimming.  If anyone wants to try some Inconel, send me a self-addressed, stamped envelope and I'll return 10 ft. or so.
Phil C
Re: Foam Cutting
« Reply #17 on: May 05, 2013, 03:15:48 PM »
Apparently folks have been cutting foam for quite some time.
I picked up this old bow and homemade power supply off the fleabay several years ago.
The germanium 2N174 transistors are dated to 1960's as far as I can figure out.
I never tried to fire it up because it runs off a cigarette lighter 12volt supply.
My apologies for the poor photography.
Re: Foam Cutting
« Reply #18 on: May 05, 2013, 03:44:51 PM »
Phil's obviously still alive, so his recommended hardware isn't always immediately deadly.
But speaking as both an electronics engineer as the son of a former Fire Marshal, and as the son and brother of a pair of firefighters who have had to scrape dead or seriously injured people off of the remains of their Really Clever home-brew projects, you can spend just a little bit more money and be a lot safer.
Most Variacs are what are called "autotransformers".  They have one end (nominally the neutral end, not ground) connected in common to both the input side and the output side.  The other side is nominally connected to hot.
For the last 50 years or so, North American house wiring uses a three-wire system, with hot (nominally 110-125V), neutral (nominally ground), and safety ground (really ground, unless there's a wiring fault).  The neutral and ground wires are supposed to be connected together at the pole, and the hot wire is connected to hot on the pole transformer (there's a whole song and dance about how to get 240 for appliances -- look it up if you're that curious).  Sockets are polarized (that's the whole irritating "you can't plug a new radio into an old extension cord" problem).
The key word here is nominal.  Neutral wires are supposed to be close to ground, but either because of wiring faults in the house, or because a given socket is mis-wired, what is supposed to be neutral can have a few volts on it, or it can have 120V.  Worse, if the guy that wired your house was sloppy, some plugs will be backwards of others.  So your "Phil Approved" Variac or dimmer could be just fine in one socket, and give you a serious shock in another.
The physical arrangement that's much more likely to avoid electrical shock is to use some sort of isolation between you and the socket.  You can get isolation transformers to put on the 120V side of things, or you can run your Variac into a 25V transformer from RadioShack (25V, 2A, $14.49).  Using the step-down transformer means that you'll be using the upper range of the Variac, which will be lighter duty for that device, and (if you wire the low voltage side correctly) the 120V side can have all sorts of faults and you will never feel a thing.
I'm not so sure about the light dimmer -- they're not supposed to be happy working into inductive loads (like a transformer), but on the other hand I've heard reports from people that they work OK.  So a light dimmer into a step-down transformer may work, and it will be a lot safer than a light dimmer alone.  And dimmers are a lot cheaper than Variacs so it may be a worthwhile thing to just try one out.
Re: Foam Cutting
« Reply #19 on: May 05, 2013, 06:28:03 PM »
Jeeze, I think I'll just forget about building planes.
        James
Re: Foam Cutting
« Reply #20 on: May 05, 2013, 08:00:53 PM »
Never!  It's a web forum -- dissension is to be expected.  Besides, as I said, Phil's been doing it his way for years so I can't speak out too loudly against it.
Re: Foam Cutting
« Reply #21 on: May 05, 2013, 08:08:20 PM »
James, I must have written wrong.  You want Marlon P. Jones not mpI.  They are the source for the transformer @ $50.  Cutting foam is not difficult but it does require a little practice.
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
Re: Foam Cutting
« Reply #22 on: May 07, 2013, 05:20:24 AM »
you can do this for about $25 bucks, or less if your scrounge.
Variacs work well.  But as someone who works around power all Day, I would not use a variac alone. For my mind designing out the shock risk is worth an extra $10.
A good source is out of an old school battery charger, or a 120- 24 volt control transformer from a furnace guy.
http://www.rcuniverse.com/forum/m_8307147/anchors_8315575/mpage_1/key_/anchor/tm.htm#8315575
Harbor freight males a nice router speed control for about $20  feed that into an isolation transformer and your are all set.
This isn't hard and there are many ways to skin this cat so don't give up.
Dave Siegler
NE9N extra class
AMA 720731
Offline Allan Perret
  • Proverbs
Re: Foam Cutting
« Reply #23 on: May 10, 2013, 08:44:00 AM »
Phil C
Dont see how the lightbulb can work as a fuse.  The bulb can take full voltage by itself and not blow.  A fault in any other part of the circuit will not cause the bulb to pass anymore amps than what it normally operates at, because of its internal resistance.
Allan Perret
AMA 302406
Slidell, Louisiana
Re: Foam Cutting
« Reply #24 on: May 10, 2013, 03:58:26 PM »
I used an American Flyer train transformer for a many years, but later decided it was foolhardy to risk an irreplaceable item like this when there is another way.  It worked OK up to about 20" cores.
Later I went to a Variac I bought off Ebay.  Much better!
More power!    Tim Allen
Re: Foam Cutting
« Reply #25 on: May 10, 2013, 04:06:53 PM »
The cutting wire is scrap .018" flying line, hence, zero cost.
Or you could just buy this for $2,999 and learn to draw your virtual templates on AutoCad.
Offline RC Storick
Re: Foam Cutting
« Reply #26 on: May 10, 2013, 05:03:20 PM »
Offline William DeMauro
Re: Foam Cutting
« Reply #27 on: May 11, 2013, 06:39:12 PM »
James,
 I'm not sure if I'm remembering right but if you have the I-charger 306B it can be used as a foam cutter to. It actually has a foam cutting setting.
William
AMA 98010
Re: Foam Cutting
« Reply #28 on: May 11, 2013, 11:24:14 PM »
Hey William,
No, I have the Power Lab 8,  does it have a foam cutting setting too? HOPEFULLY.
Re: Foam Cutting
« Reply #29 on: May 12, 2013, 08:19:09 PM »
Sorry James,
 I've helped a bunch of people get their e-planes set up sometimes I forget who is using what charger and for some reason thought you were using the I-charger 306B. Besides the 306b, I am also using a PL8 but I don't believe that has a foam cutting setting.
William
AMA 98010
Re: Foam Cutting
« Reply #30 on: May 12, 2013, 08:44:03 PM »
Thanks William, well can you recommend something for me to use? James  hey remember
I have your 12/ 24 VDC  55A power supply, I just need a way to regulate it to cut foam,any
ideas?
Offline david beazley
Re: Foam Cutting
« Reply #31 on: May 14, 2013, 05:20:25 PM »
I use a 12 volt car battery charger.  You can also use a car sized 12v battery.
AMA # 2817
Re: Foam Cutting
« Reply #32 on: May 14, 2013, 09:31:48 PM »
David, How do you control the temp of the wire?
Re: Foam Cutting
« Reply #33 on: May 14, 2013, 10:35:29 PM »
James -- I assume it's not an adjustable supply?
Re: Foam Cutting
« Reply #34 on: May 15, 2013, 12:45:40 AM »
I gotcha Tim
Re: Foam Cutting
« Reply #35 on: May 15, 2013, 06:46:12 PM »
The charger I use is an automatic charger.  I use .012 SS wire and the charger sets the amperage.  The bow is about 3' long and I use alligator clips to hook the leads to the wire.  I move them closer or farther away from each other to change the resistance and temps.  I am not an electrical genius so I don't pretend to know about electrons.  It just works for me.  If anything I would like more oomph it cuts a little slow but I'm not going to invest a lot in to it.
I hopes this helps.  One thing I do is suspend the bow from the ceiling with rubber bands so I don't have to hold it up when I cut.  This way I can concentrate on keeping the wire moving on the templates.
AMA # 2817
Online Howard Rush
Re: Foam Cutting
« Reply #36 on: May 17, 2013, 02:19:09 PM »
I think that it's important to have a low impedance power supply feeding the wire.  If you have a resistor in series with the wire (a potentiometer or a light bulb, for example), the voltage across the cutting wire will decrease as the wire cools and increase as the wire heats up.  That makes it hard to control the wire temperature, which you do with cutting speed.   Two ways I've used to get a low impedance supply are a light dimmer driving a hefty transformer and a garage-sale Variac driving a hefty transformer.  Old audio amplifiers are good sources of hefty transformers.  Mind you, I haven't made any quantitative measurements (I probably did, but I don't remember what they said nor where I put them), so this is kinda conjecture, but I learned how to cut foam well after several years of trying.
The idea of using RC equipment is really cool.
Through-hole man trapped in a surface mount world
Re: Foam Cutting
« Reply #37 on: May 17, 2013, 02:54:31 PM »
>>I probably did, but I don't remember what they said nor where I put them<<
If have seen Howard's shop, this is perfectly understandable.
Re: Foam Cutting
« Reply #38 on: May 21, 2013, 05:06:00 PM »
Well, all I know is I hooked the gizmo up, with 110 on one side of the wire.  An accidental short blew out the bulb.  Then I checked the voltages and fixed 'em to avoid further surprises.
