  • June 18, 2025, 07:06:18 PM
Author Topic: What is the right position for the control line bell crank  (Read 6954 times)
Offline Jonathan Chivers
« on: April 29, 2013, 01:10:07 PM »
Hello all,
looking at a number of plans, it looks like there is a general rule of thumb that a plans CoG will be around 25% of the root wing chord back from the leading edge and the bell crank about 30% back.
I understand that moving the CofG forward will make the plane more reactive to the elevator and further back less so, but what it the impact of moving the bell crank position forward and backwards?
If this has been covered before, please point me at the right link.
Jonathan
Re: What is the right position for the control line bell crank
« Reply #1 on: April 29, 2013, 01:26:43 PM »
I am going to make a couple of  comments befor this subject crashes.
First, for the CL models of ours, the CG is "normally" around 20 to 25% of the mean aerodynmic chord (which for most practical purposes would the the average chord of the model.  A more forward CG will make the model somewhat more stable and less maneuverable.  There is a limit to how far forward the CG can be and that is where there is insufficient elevator authority to lift the nose.  A more rearward CG will make the model more responsive and beyond a certain point, the model will become more unstable and less controllable
Now, regarding bellcrank position.  Suffice it to say that the bell crank can be located anywhere.  What is important is the position of the leadout guides relative to the CG.  However, there are some practicle considerations for the bellcrank position.  It makes sense to position the bellcrank somewhere near the CG.  This will minimize the flex of the leadouts at those leadout guides.  Also, it makes sense to locate the bellcrank where there is room to do so and structurally where it is practical to do so to minimize any additional structure.
This has been argued many times over the years on these forums, but the above regarding bellcrank position is a time proven fact.  You can probably do a search here and just might find a bit of information.
Now wait for incoming.
« Reply #2 on: April 29, 2013, 01:37:40 PM »
Keith said it simply and accuratly,,
for a more exhaustive telling  use the "search " function and you will stay entertained for hours, perhaps days,,
or just go with what Keith said and save the hassle LOL
« Reply #3 on: April 29, 2013, 01:43:31 PM »
Positioning the bellcrank to minimize leadout bending at the wingtip is important.  Even so, our typical 4" crank causes considerable narrowing of the leadouts through the wing panel to the tip guide.  Friction there is always a problem.
It also makes sense to have the bellcrank mount (or pivot wire) close to the main spars, to provide a good anchor to the strong point in the wing.
Most C/L stunt plans show  correct mounting.  If not, it helps to draw it out on the wing plan to get the best angles for leadouts, etc.
« Reply #4 on: April 29, 2013, 01:52:09 PM »
To expand on what Keith and Floyd are saying:
Practical considerations:
In a world where leadout flex and friction did not matter, you could put the bellcrank any place where it would fit as it traveled through its range.  (In fact, some early control line planes hooked the leadouts to the elevator horn and put pulleys in the fuselage or wing to help them turn the corner.  This worked, kinda, but was really done to dodge Jim Walker's patents, rather than for any functional reason).
What matters to the flying of the plane is the position of the leadouts on the wing, the amount of friction, bind, springback, throws vs. line motion, etc., in the control system itself, the whole shebang being able to withstand the pull of the aircraft on the lines, and the CG position.
That having been said, the more that you ask the leadouts to bend on their way from the bellcrank to the ends of your lines, the more that you are flexing the leadouts and the more friction you are creating between the leadouts and the leadout guides.  Similarly, the way that you mount the bellcrank with respect to the flap or elevator horn affects the friction, springback, and throw ratios of the control system.
In general, bellcranks are placed so that the link to the outside world (usually the flap horn on a stunter, or the elevator horn) is a straight shot without opportunities to bind.  You generally see them placed as forward in the wing as they will go without making the wing construction inconvenient (which is why they're often a bit behind the CG).  You will sometimes see bellcranks located at a tilt when viewed from the side of the plane: some people feel this gives a more favorable geometry with respect to the flap horn (and will often couple this tilted bellcrank position with a flap horn that has a dog-leg in it).
Social considerations:
There are some people who are convinced that the above is not true.  They will tell you that where you put the bellcrank in the wing changes how the plane flies because of the direction that the leadouts pull on the bellcrank.  The notable myth is that the bellcrank must be as close to the CG as possible, and moving it back destabilizes the plane.  You must choose yourself whether to believe them -- but keep in mind if you do that they are going against some pretty basic principals of physics.  The position of the bellcrank in the plane does matter for the reasons I gave, but it's not going to make the plane stable or unstable unless there's friction, spring, or bad control geometry involved.
« Reply #5 on: April 29, 2013, 02:11:40 PM »
If Bernie Ash could make the bellcrank position and leadout position in the Supersonice Stunter to work, they you really can put the bellcrank anywhere. But Keith's points are quite valid and looking a drag and possible binding at the leadout guide is an important consideration.
Online Howard Rush
« Reply #6 on: April 29, 2013, 02:49:04 PM »
Keith said it very well.
Offline RC Storick
« Reply #7 on: April 29, 2013, 07:46:42 PM »
Bill Netzeband wrote in his Control Line Capers column, American Modeler, October 1962:
"Misconception Blasted. Pictures illustrate that the bellcrank has NO effect on locating the CG. Rather, the bellcrank should be ON the CG to prevent binding (Pic #2). CG will always fall in line with the center of line lead-out spacing (1, 2, & 3) during flight. Locate your leadouts relative to the CG to produce desired yaw angle for proper tug. ... Next time a guy tells you to locate your CG forward of the BC or in front of the lead out, shun him. He don't know the facts. The CG comes first, all else is related to it."  LL~
« Reply #8 on: May 08, 2013, 12:47:07 PM »
Thank you for everybody's replies.
Jonathan
Offline Jim Thomerson
« Reply #9 on: May 08, 2013, 03:18:25 PM »
For some time I have been using short pieces of the yellow inside tubing from nyrod control tubing in my leadout guides.  I think they minimize friction, and show no wear, compared to metal tubing.
« Reply #10 on: May 11, 2013, 12:26:54 AM »
When you trow side area distribution and side wind in a howling gale into the equation , the poistion of the bellcrank becomes somewhat more relevant .
As when the side lod from cross wind exceeds the centrifugal effect , It is Dominant or greater . laterally . The things not so simle as a static gravitational loading .
Airflow & load distribution are considerable influance .
My perception is that leadouts near straight to handle induces lateral stability in giusts & 20 knot wind . Have operated in these conditions thus with C.G. slightly aft
of bellcrank pivot . But the suckers got a few tricks to neutalises forces / loadings . Substantial shock loads at bottom of Sq's in funnelling 20 Kt ground winds .
Any lack of dimensional stability in structure could lead to divergant flight path . As would elasticity in lines .
presumably strongly raked leadouts would produce stong yam responce in gusts or under laterl loads across downwind .
pity some assholes smashed the planes shipping them . A years worth of building to replace the things . One of these days .
Online Howard Rush
« Reply #11 on: May 11, 2013, 02:25:28 AM »
I stopped by the Paul Walker Stunt Ranch on the way to the 2012 Nats.  Paul had some nice Delrin (I think) leadout bushings he got from Roy Trantham. After awhile he offered me a couple of them.  I thanked him and revealed to him that I had already stolen a pair.  September found me in Pennsylvania, so I went by Bob Hunt's shop, which is always educational.  He was showing off his stash of the same bushings.  I took a handful.
Offline BillLee
« Reply #12 on: May 11, 2013, 06:57:24 AM »
Picture, Howard?
Bill Lee
AMA 20018
Offline dirty dan
« Reply #13 on: May 17, 2013, 11:50:12 AM »
You could come by the house, using mill and lathe to make your own Sooper-Zoot leadout guides. Pieces to which no one else has access, especially as you will needlessly design them to be three times more complex than need be.
I have black Delrin. If you want white Delrin pick some up at Tapp's in Bellevue on your way north.
Caution: There is nothing in garden ripe enough to eat. Some Vegetables from Outer Space are doing nicely but still a month or so out...
So fabricating your leadout guides from kohlrabi roots probably not an option.
Dan
Dan Rutherford
