  • August 02, 2025, 03:43:05 PM
Author Topic: Drill jig for flaps and elevators  (Read 1997 times)
Offline jim gilmore
« on: January 28, 2009, 10:17:37 PM »
Does anybody make and sell accurate Drill jigs to drill straight holes in 1/8,3/16 or 1/4 material for flaps and elevators?
I could draw a tool to do it but I do not have access to a machine shop ?
Offline Dick Fowler
Re: Drill jig for flaps and elevators
« Reply #1 on: January 29, 2009, 05:24:04 AM »
Dubro makes such a thing. Not very expensive and works pretty well..
http://www.dubro.com/hobby/ecatalog/dubro/00039.htm
Dick Fowler AMA 144077
Kent, OH
Offline Vincent Corwell
« Reply #2 on: January 29, 2009, 07:24:05 AM »
I think Al Rabe posted pix of a neat jig
for drilling the flaps for the horn some
time ago ??
not sure if the Dubro item is for hinges only
Vincent
Online Alan Buck
« Reply #3 on: January 29, 2009, 10:15:27 AM »
What Ty said but I drill mine before I taper them it will work both ways
ALAN E BUCK
Offline Dennis Saydak
« Reply #4 on: January 29, 2009, 10:29:27 AM »
You can easily make jigs. I use aircraft ply with a maple center core. Drill the flap before shaping it. Hope this helps.
Offline jim gilmore
« Reply #5 on: January 29, 2009, 11:04:12 AM »
Hey Dennis, Your wood Jigs look just like I was trhinking of only I was thinking aluminum. Might have to try doing wood myself.
« Reply #6 on: January 29, 2009, 08:55:29 PM »
It wouldn't hurt to make the jig out of wood and then install a hardened drill bushing of the size you want. I happen to think it's easier to put in an RSM "Lucky Box", 'cause I want my flaps removeable anyway. :D Steve
Online Alan Buck
« Reply #7 on: January 29, 2009, 09:48:38 PM »
Hi TY had to miss koi do to Diane being in the hospital for a operation
ALAN E BUCK
Offline builditright
  • So happy to be alive!
« Reply #8 on: February 23, 2009, 04:54:23 PM »
Hi Jim,
I also make Lucky Boxes, As Steve mentioned they're much easier to install.
make a few cuts and no more drilling
see photo'
Thank you and God Bless
Walter
aka/ builditright
Online John Paris
« Reply #9 on: February 23, 2009, 07:17:24 PM »
I like to go for the simple solutions that use stuff I have hanging around the shop.  Basically I just pin the flap or elevator to a piece of 2x4 resting on the "2" side (this needs to sit up straight when flipped) as it sits on a flat surface.  Then I flip it over and drill the hole at the point where I have already marked the centerline of the wood and the position of the hole.  So far, so good and convenient.  The only down side is that it only works for the straight trailing edges.
John Paris
269
