  • June 18, 2025, 05:12:17 PM
Author Topic: dope thinner  (Read 3218 times)
Offline louie klein
dope thinner
« on: November 06, 2017, 05:12:44 PM »
Hi guys, I bought a bunch of cans of dope "Sig Supercoat" and "aerogloss". Does any one know what thinner I can get from an auto supply that is compatable Thanks---Louie
Offline 944_Jim
Re: dope thinner
« Reply #1 on: November 06, 2017, 06:01:02 PM »
Hi,
I came across a bunch of the same, antique dopes.
I clean with the left, and thin with the right.
Left is from Lowe's, right is from Walmart.
Re: dope thinner
« Reply #2 on: November 06, 2017, 07:11:47 PM »
    Be careful when using these two brands. You will have comparability problems with them. OIf you start with one brand, finish with one brand. I believe the way ot went was you can put other dope over Aerogloss, but you can't put Aerogloss over any other kind of dope. It may have held true if you used Aerogloss thinner. It changed formulas several times over the years and I had heard at one time that it was comprised of 14 different solvents! Apply to a test piece before trying on a model. Allow maximum gas off time between coats.
Offline Sean McEntee
Re: dope thinner
« Reply #3 on: November 06, 2017, 08:01:12 PM »
Didn't you use Dupont 3608S for Sig dope, or was that just for the MILSPEC stuff?
Re: dope thinner
« Reply #4 on: November 06, 2017, 09:22:22 PM »
 A hundred years ago, in my beginner days, I used to use Aerogloss and it would lift off of the fillets every time. I think it was mainly because it shrank so much, it would lift and you'd end up with a big hollow bubble inside about any tight corner. It does act a lot different than "normal" dope. These days I'd say it would be wise to just toss it in the round file.
Re: dope thinner
« Reply #5 on: November 07, 2017, 12:03:44 PM »
I will refrain from my usual rant about using compatible materials. I've found over the years that people don't really want to hear that they cheap thinner they both from Joe's Hardware probably will cause problems with the Brodak dope they have.
Re: dope thinner
« Reply #6 on: November 07, 2017, 05:51:06 PM »
The guys in British Columbia and Alberta report that the lacquer thinner they buy at Home Depot works fine in Brodak/Randolph butyrate dope. Apparently, it's different than what Home Depot sells here in the USA. Next trip to BC, I plan to find a Home Depot and smuggle a gallon across the border. It should say what's in it, and I can compare that to the stuff they stock here.  ;D Steve
PS: Take the lids off the AeroGloss and let it dry out completely. Dispose of in the garbage. Yes, that's the legal method of disposal for all household paints.
Re: dope thinner
« Reply #7 on: November 07, 2017, 05:59:20 PM »
 I'll second that suggestion.  ;D
