  • June 19, 2025, 04:19:00 PM
Author Topic: Help making two identical landing gear legs.  (Read 1029 times)
  • Gravitywell
« on: February 17, 2010, 05:44:43 PM »
Hi all.  I am wanting to bend the landing gear for my RM +P and have trouble making two that are identical.  I saw somewhere that one fellow was somehow bending two wires at the same time, thus making them the same.  They were attached to each other somehow, but I can't remember if they were just soldered together, or were done in some other manner.  Any help on jogging my memory would be greatly appreciated.  Thanks.  H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Re: Help making two identical landing gear legs.
« Reply #1 on: February 17, 2010, 07:15:03 PM »
I posted that.
I soldered two pieces of 1/8" wire together, bent them, then melted the solder.
Solder melts in the 400-450 degree range.  You need to get steel up over 1500 degrees to damage the metalurgy.
Offline Russell Shaffer
« Reply #2 on: February 17, 2010, 08:48:54 PM »
There's a simple idea that I never though of.  Thank you.
Russell Shaffer
Klamath Falls, Oregon
  • Gravitywell
« Reply #3 on: February 17, 2010, 09:10:31 PM »
Thanks guys...thats the info I needed.  I think I was trying to make it harder than it was.  Thanks again! H^^
Glenn Reach
Westlock, Alberta
