  • June 20, 2025, 12:49:21 AM
Author Topic: tanks a lot  (Read 1565 times)
Offline roger
tanks a lot
« on: June 24, 2010, 01:32:53 PM »
anybody ever build a fuel tank from a 35 mm film can? need some diagrams ...
Re: tanks a lot
« Reply #1 on: June 24, 2010, 08:53:28 PM »
There was an article in Flying Models within the last 5 years or so, about making tanks from various things, including plastic 35mm film "cans" and plastic bottles. The guy drilled holes, pushed silicon fuel hose in, then pushed metal tubing through. The silicon fuel tube worked as a grommet or o-ring sorta thang. No reason it wouldn't work for a 1/2a or .09. There weren't any actual diagrams of where tubes should go, and of course, it was really all about arcee.  D>K Steve
Re: tanks a lot
« Reply #2 on: June 25, 2010, 08:35:35 AM »
Contact MinnesotaModeler.  He posts on here and I think he was the first.  Don't trust my memory tho. H^^
Re: tanks a lot
« Reply #3 on: July 05, 2010, 03:11:02 AM »
Ray does use the film can, but IIRC, he uses a balloon inside of it, now.  The balloon is not *pressurized, just a *floppy* balloon.  The can is for protection now, I guess! ;D  (and it works great on 1/2A's!
Big Bear
Offline Larry Renger
Re: tanks a lot
« Reply #4 on: July 09, 2010, 09:47:05 PM »
The Flying Models article was "Tanks fer nuttin' " written by yours truly.  The key is to get things like travel mouthwash, 35mm film cannisters, etc and use them as fuel tanks.  Goop adhesive works really well, and it almost perfectly fuelpproof, though it does degrade with time.  The article was in the April 2002 issue.  Also there have been many discussions and some good how-to's in the 1/2A forum section here in Stunt hangar.
I have shot some photos of one of my current film container tanks, but as I am "breaking in" a new computer, I can't downsize the files at present to show here.   HB~>  Perhaps in the next day or so.
My favorite is the old (obsolete) APS film containers from Fuji film.  They are clear, have a great seal, and the cover is square, so the tank it easy to align.
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: tanks a lot
« Reply #5 on: July 10, 2010, 06:13:49 AM »
I seem to be a little late to this party, but here's some pix of a "hard" tank made from a canister, alum. tubing, and Goop. The silicone fuel line is forced through a slightly smaller hole, if sized right it seals up fine. This one is set up as a uniflow clunk.  It worked fine for a couple of years in an .061-powered stunter now crashed, repaired and retired.
I've done several other configurations, with round canisters as well as this oval one, fixed lines as well as clunk.  Made some oversize ones (my .061s are thirsty) by cutting out the bottom of one and splicing it to another, gooped together.
Couple of caveats: Choose a canister with a tight-fitting lid (they vary).  Rough up the plastic with sandpaper before applying Goop.  Let the stuff cure for a week or more before exposing to fuel.
--Ray
AMA902472
Re: tanks a lot
« Reply #6 on: July 12, 2010, 06:28:43 PM »
And, here are my photos.   ;D
    • Minnesotamodeler
Re: tanks a lot
« Reply #7 on: July 12, 2010, 07:44:20 PM »
Love the Hornet...I don't spose you've got an extra laying around, huh?
--Ray
AMA902472
Re: tanks a lot
« Reply #8 on: July 13, 2010, 03:21:03 PM »
3 more, actually.   ;D
    • Minnesotamodeler
Re: tanks a lot
« Reply #9 on: July 13, 2010, 03:50:03 PM »
Any for sale?  That was my dream engine as a young teen.
--Ray
AMA902472
Re: tanks a lot
« Reply #10 on: July 13, 2010, 09:44:53 PM »
Thanks, Ray! (and Larry, too! ;D
Don't you use party balloons to make tanks?
Re: tanks a lot
« Reply #11 on: July 13, 2010, 10:58:49 PM »
Yes, well documented here.  Do a search on balloon tanks, and it is all layed out for you in detail with photos.  Several times, actually.
