  • June 19, 2025, 01:04:37 AM
Author Topic: Control Surfaces  (Read 996 times)
Offline Bryan Higgins
Control Surfaces
« on: March 10, 2008, 01:38:19 PM »
Hello Modelers
I need help with my flaps and elevator movement.
Flaps move 3/4" each way.
Elevator moves 1 1/8" each way.
Do i have enough movement ?
                            Thank You  Bryan Higgins
Bryan R higgins Jr.
Arvada,Colorado
AMA#885188
Offline Chris Gilbert IRL-1638
  • EI-1638
Re: Control Surfaces
« Reply #1 on: March 10, 2008, 02:22:54 PM »
That sounds like loads, maybe even too much.
I usually set my models up with 30 degrees flap (1/3 of the flap length in either direction) and start off with the elevator at 1:1 (30 degrees).
I read somewhere that more than 30 degrees for flaps is ineffective so that's why I stick with this number.
I usually allow to increase the elevator movement to 45 degrees, to give the model more urge in corners, if it needs it.
IRL-1638
« Reply #2 on: March 10, 2008, 02:39:21 PM »
1/3 of the flap length. and 1:1 for flap and elevator. 30 degrees.
Thank You , I now it sounds dumb but it's nowhere on the plans
or manual. So i been digging through my books. Just want to
get things right before i move on.
I appreciate the help.   Bryan
Bryan R higgins Jr.
Arvada,Colorado
AMA#885188
