  • July 13, 2025, 09:58:10 AM
Author Topic: Complicated Profiles Redux - Oh no, another pic  (Read 26416 times)
Re: Complicated Profiles Redux - Oh no, another pic
« Reply #50 on: March 02, 2009, 02:34:35 PM »
Dennis,
You did noitce the big holes in the fuse, didn't you? Moths?   (PE**)
Offline Dennis Moritz
« Reply #51 on: March 02, 2009, 02:36:29 PM »
Waiting for the moths to spin some silk. Spring?
« Last Edit: March 02, 2009, 02:53:57 PM by Dennis Moritz »
« Reply #52 on: March 02, 2009, 04:14:50 PM »
 ;D
Offline afml
« Reply #53 on: March 02, 2009, 07:08:23 PM »
"Dan Banjoks madness, a re-plumbed Tettra Tank-- the fuel is stored exterior to the blatter instead of inside the blatter. Air is sucked out of the blatter and capped, tank is filled full, feed line attached to the engine, blatter is uncapped and attached to muffler pressure. Tahh Dahh, no air bubbles, engine runs an excellent 4x2 break (La46) engine goes lean for two laps and shuts off."
Dennis, could you give me a few more details of the tank set-up?   #^
What is the "blatter" made from?
Any air entering the tank other than in the "blatter"?
GREAT looking plane and SUPER workmanship!
Thanks for sharing!   y1
"Tight lines!"
Wes
Wes Eakin
« Reply #54 on: March 02, 2009, 09:36:47 PM »
Well, here it is all assembled. It's still a ways from ready to start finishing. There's a lot of sanding to be done between now and then. And I really don't like the landing gear setup much. I'll probably dump it and do something else. Sigh...
« Reply #55 on: March 02, 2009, 10:29:59 PM »
See they were all right,, we dropped the displacement limit and now all this hi tech profiles come out of the woodwork! S?P S?P S?P
Looks pretty cool Randy, I still say a nice aluminum gear leg set would look totally sweet,, but hey what do I know,, I cant stay awake long enough to ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, Z@@ZZZ Z@@ZZZ
« Reply #56 on: March 03, 2009, 09:19:24 AM »
Mark,
It may be what I do. I'm not at all happy with the gear. I'll probably come up with something else.
Hey, it's a .40.   ;D
  • Gravitywell
« Reply #57 on: March 03, 2009, 09:24:50 AM »
Hi Randy.  So you want some inovative landing gear eh?  Well go here, http://www.brotherhoodofthering.info/flightline/forums/thread-view.asp?tid=1924&posts=20&start=1  and look at what Bill Gruby has designed for landing gear.  Wayyyyyy cool! H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Online Matt Colan
« Reply #58 on: March 03, 2009, 09:25:06 AM »
Looks great Randy, I like it.  It sure looks complicated...for a profile with the pipe and all.
« Reply #59 on: March 03, 2009, 10:02:23 AM »
Hey Wes,
Thanks for the compliment about the Cardinal, but it was an ARF, I stripped the covering added the engine plates and fiberglassing. Wouldn't call that building. Do you mean Randy's plane?
The word is badder-- I misspelled the word, it isn't "blatter," sorry, I am spelling challenged often identifying words via sound. Also hard to think straight late at night or... when...
The bladder in Tettra Tank appears to be made of silicon. Tho I'm not positive. It is clear and flexible. The Tettra is a commercially available tank typically used in RC Pylon racing. As designed, the bladder is enclosed in a plastic tank, same as a clunk tank. The bladder is filled with fuel, expanding into the clunk tank space. Air is let out of the bladder, so that the bladder contains only fuel, no air, eliminating air bubbles which effect the fuel/air mixture going to the engine. Dan went to a Tettra Tanks to solve vibration/air bubble issues on a P40 ARF.  Weird vibrations are a frequent problem with profile models. The Tettra Tank worked fairly well, but the engine broke lean ten laps or so before the end of a flight. Too long a lean run. It appeared that the bladder did not collapse evenly causing a slight vacuum, making the engine run lean. To counteract this Dan tried storing the fuel exterior to the bladder, in the hard tank itself, same as one would do in a conventional clunk setup. The bladder was then used to expand into the tank as fuel is burnt off. Air is let into the bladder, not into the hard tank, so that air doesn't mix with unburned fuel.
Details of the plumbing have to wait. Dan hasn't draws them up. It's possible a magazine article will be published detailing the system Dan devised.
« Reply #60 on: March 03, 2009, 11:37:30 AM »
Glenn,
Yea, molded plywood gears are pretty cool. While I was sitting in a really boring meeting this morning (occupational hazard), I designed a gear that I think will work. I'll see about cutting a mold tonight. Big cool factor. Hey, if you're going to go this far out on a limb, might as well come up with something cool, right?
Online Matt Colan
« Reply #61 on: March 03, 2009, 05:21:37 PM »
Glenn,
Boy Randy, great minds think alike.  When I am going through something BORING in school, I draw up stunters that I might design.  Basically brainstorming.
Don't worry, I still have good grades, A's and B's so my parents still let me fly these planes.
« Reply #62 on: March 03, 2009, 06:42:06 PM »
I think profiles like Randy's (and Bob Branch's hybrid) are really exciting to look at - there are a lot of shapes there that you don't normally see, lots of eye candy there.
« Reply #63 on: March 04, 2009, 09:06:36 AM »
OK, so last night I dumped the landing gear, cleaned up the area and put in a new mount system. Then I made a plug for a new landing gear and coated it in epoxy. Tonight I will sand that down and start making a mold. Should make me happier. The original was starting to look like the gear for a 30s air racer with guy wires and such. Other that that, it's ready for final sanding and finish. I need to slip by the local screw place today to pick up the mounting bolts. I dont' have any long enough.
Offline Rod Claus
« Reply #64 on: March 04, 2009, 09:58:42 AM »
Randy,
That thing is really cool!! Looks like a Impact influenced wing.I can hardly wait to see you ,Haverly's new profile with a pipe plus Dan's Wimpact duke it out this summer.This is a neat direction that we are going.
I've got a bunch of OS40 FSR's that might work well on a pipe.I will start a scratch Pathfinder when I get back in April.........Hmmmmm
Rod Claus
Kent,Wash.
« Reply #65 on: March 04, 2009, 12:57:01 PM »
Rod,
Closer to a Werwage wing. Fairly thin airfoil with the high point back further than I usually do. A slightly thicker Novi airfoil.
Offline Bill Gruby
« Reply #66 on: March 04, 2009, 01:23:39 PM »
 Randy;
  Anything but "Ringmonster" for that beauty. "Ringmonster" just does not do it any justice. If you go with molded plywood for the gear, I would use no less that 5 layers of 1/64 because of the size. If you go 4 layers, put one layer of CF in the middle of the gear. The gear on my Bipe is molded 1/64 in 5 layers with no CF. It is bullet proof.
  You do nice work.
  "Billy G"  D>K
Bill Gruby
AMA 94433
MECA 5393-10
« Reply #67 on: March 04, 2009, 09:19:19 PM »
Thanks Bill. I suspect I'll just mold up a CF gear, though using 1/64" plywood is intriguing. I have the plug finished but ran out of poop tonight. I will start on the mold box tomorrow. Should have it don't by the weekend. I just wasn't happy with the wire job. This wil work a lot better.
Offline Bill Gruby
« Reply #68 on: March 05, 2009, 04:46:37 AM »
 Randy;
  This is the molded 1/64 plywood for my Electric Ducted Fan Ringmaster. These were a real pain to mold.  LOL I have the ply gear on my S1 and Bipe . No problems yet. The second picture is the mold with gear in place. 22.4 grams total, wheels, axles, and gear. The wheels are "Delrin" w/O-rings for tires. Axles are aluminum, all made by me.
  "Billy G"   H^^
Bill Gruby
AMA 94433
MECA 5393-10
« Reply #69 on: March 05, 2009, 11:08:11 AM »
G-man, you need to refine that mold, it looks a bit rough,, LL~ LL~
maybe make the next one from aluminum,,,,,,
« Reply #70 on: March 05, 2009, 12:40:58 PM »
An electric ducted fan Ringmaster? Wow, you really are out of control. My kind of guy.
Offline Bill Gruby
« Reply #71 on: March 05, 2009, 01:28:55 PM »
 Out of control, I resemble that remark. LL~ LL~ You're gonna love this one.
  "Billy G"   VD~ VD~ VD~
Bill Gruby
AMA 94433
MECA 5393-10
« Reply #72 on: March 05, 2009, 10:44:35 PM »
Big G,
Wow. Now that's outta control. Very slick.
« Reply #73 on: March 07, 2009, 07:57:07 PM »
Well, I got the first leg out of the mold. Looks OK, though it will need a bit of cleanup. Trying to make molds when the temp is low is a challenge. but it's coming out OK in the end. First coat of dope on the fuselage.
« Reply #74 on: March 08, 2009, 09:01:04 PM »
Man, I hate retrofitting. I had already made the wheelpants and the mount of the fuse, so I had to go back to rework the whole thing for the new gear. What a pain. But, one side is done and I'm waiting for the other gear to cure. I'll finish up the retro fit probably tomorrow or Tuesday, then I can get back to finishing this thing.
Anyone know a good source for 2" long 6-32 socket head screws with a 1 3/4" shoulder?
« Reply #75 on: March 08, 2009, 09:44:26 PM »
Randy try Fastenal
Offline Rod Claus
« Reply #76 on: March 09, 2009, 10:01:21 AM »
Randy,
Try one of the many Tacoma Screw or Hi-Strength Bolt outlets in our area.......
Rod Claus
Kent,Wash.
« Reply #77 on: March 10, 2009, 10:41:53 PM »
Rod,
Went to Tacoma Screw and High Strength Bolt. No joy. I was able to order them from Micro-Fasteners, but had to get a box of 20. Oh well, I'll find some use for the extras. At least I was able to other some other stuff I was low on.
Offline Bill Gruby
« Reply #78 on: March 10, 2009, 11:28:16 PM »
 Randy;
 Am I reading this correctly -- you want a 6-32 cap screw 2 inches long with only 1/4 inch of thread?
 "Billy G"  ???
Bill Gruby
AMA 94433
MECA 5393-10
« Reply #79 on: March 11, 2009, 09:44:27 AM »
Bill,
Yea, pretty much. I changed the gear layout and ended up molding up two piece a CF job. This required a new mount on the fuse. The easiest way was to use plywood plates over the original hardwood mount. This makes the distance between the plates about an inch and a half. Add the thickness of the gear and 2" just makes it through with a bit over an 1/8" left. I wanted 1.75" of shoulder, but an inch and a half was all I could get. The layout is a bit weird. I hate retrofitting. Had I done this from scratch (or been willing to cut the entire area out and do it again - too much work), I would have gone about it differently. The whole operation sort of defeated the original purpose; to build the plane entirely (or almost entirely) out of the balsa scrap box and what I had laying around. Most of it is. Designing and building a new unit (the landing gear) was not on the agenda. Sigh...
Oh well, it's coming out OK in the end. I'm trying to decide, since I blew the original concept anyway, if I want to buy some Monokote or use the very old stock I have. Again, keeping with the original concept of using what I had laying around. We'll see.
« Reply #80 on: March 11, 2009, 10:42:38 AM »
Randy,
just a thought,, If you decide t use what you have, how old is it,,, I know sometimes the old stuff if its been around a few years,, and has heat and cool cycled a few times can be pretty frustrating to get to stick and shrink,, I guess it ages or some foolishness...
and if your buying,, Look at Ultracote,, much nicer to work with,, though it doesnt have that really nice plastic fake gloss like Monokote does,,, H^^
« Reply #81 on: March 11, 2009, 04:45:52 PM »
Mark,
The stuff I have around is about 10 years old, but it's in unopened tubes and was in my closet all this time, not in the shop. But it's too late, I broke down and ordered some today. Decided I really liked the idea of transparent yellow.   ;D
Offline John Miller
« Reply #82 on: March 11, 2009, 06:10:24 PM »
Hey Randy, guess what transparent yellow looks like when it's applied over silkspan? S?P H^^
« Reply #83 on: March 12, 2009, 12:10:54 PM »
Which is why it won't be over silkspan.   ;D
