  • June 20, 2025, 12:32:55 AM
Author Topic: Sig P51  (Read 1531 times)
Offline Steve Hines
Sig P51
« on: November 13, 2010, 07:48:03 AM »
Should the control surface's be tapered, flaps, elevators, Rudder. Should this be left flat. Is there a reason for one or the other.
Thanks Steve
Offline Leester
Re: Sig P51
« Reply #1 on: November 13, 2010, 09:10:26 PM »
Without getting my kit out and looking at the plans I'd say yes unless there 1/8" but there probobly 1/4". The fin and rudder I normally leave the outboard flat and taper the inboard side.
Leester
ama 830538
Offline Jack Mulinix
  • AMA 917877
Re: Sig P51
« Reply #2 on: November 13, 2010, 10:03:05 PM »
Hi Steve, I finished mine up this last spring. Just rounded the vertical stab & rudder, tapered elevators, flaps v'ed leading edge and rounded. Can't say how it worked as I have'nt flown yet. What power you running? Jack
Offline Steve Hines
Re: Sig P51
« Reply #3 on: November 13, 2010, 11:03:01 PM »
Going to try a fox 35 with the hemi head and stuffer back plate
  • AMA 917877
Re: Sig P51
« Reply #4 on: November 13, 2010, 11:42:07 PM »
I should think that should be good, since it shows a fox on the plans. Did you use the plastic turtle deck? I ditched mine and used balsa. don't know if it saved any weight, but turned out ok
Re: Sig P51
« Reply #5 on: November 14, 2010, 01:05:17 AM »
Mine flies pretty good with flat control surfaces. As Jack said, ditch all the plastic crap in the kit and use balsa.
Offline Steve Hines
Re: Sig P51
« Reply #6 on: November 14, 2010, 08:01:16 AM »
I was thinking of making new out of balsa or covering the plastic with silk span. Getting the wing in the fuse with the flap horn on is going to be hard. I dont have the instruction sheet building off the plans. Justs seen yesterday that I did not put in the tail wheel, now this should be fun.
  • AMA 917877
Re: Sig P51
« Reply #7 on: November 14, 2010, 09:25:24 AM »
Steve, you cut the bottom of fuse,diagonally, just behind leading edge and at trailing edge. Seems like its on the plan side view. Might be able to cut a little section of the bottom sheeting off, leaving the stringers to mount the tailwheel platform on and re-sheet. Hope that helps Jack
Offline Leester
Re: Sig P51
« Reply #8 on: November 14, 2010, 09:32:01 AM »
Steve, give me a couple of hours and I'll get my kit out and scan the dirrections and either post them or E-Mail them to you.
Leester
ama 830538
Offline Leester
Re: Sig P51
« Reply #9 on: November 14, 2010, 09:45:29 AM »
Steve, Got to it sooner. Sending you an email.
Leester
ama 830538
