  • July 18, 2025, 01:03:33 AM
Author Topic: Carbon Fibre rod instead of bolt for bell crank  (Read 2506 times)
Offline Phil Goldberg
  • Just completed this PDK Buster 45
« on: July 02, 2015, 06:40:51 PM »
I am building a ringmaster and thought I might use a carbon fiber rod instead of a bolt or metal wire for mounting the bell crank.  I know the bolt or metal rod is much stronger but the distance between the plywood mounts is so short, about and inch or a little longer, that it seems in order to break a carbon rod that short, the ribs would give way first under the pressure.  Thought I might save some weight.  Has anyone done this with success?
Offline RC Storick
Re: Carbon Fibre rod instead of bolt for bell crank
« Reply #1 on: July 02, 2015, 06:49:34 PM »
I would not do this. Use piano wire
Offline jfv
« Reply #2 on: July 02, 2015, 07:23:41 PM »
Ditto what Robert said.  The CF rod would be prone to wear.
Jim Vigani
« Reply #3 on: July 02, 2015, 08:12:01 PM »
What Jim said -- CF will wear much more quickly than metal would.  It's such a small bit, you're not adding that much weight.
« Reply #4 on: July 02, 2015, 08:14:15 PM »
Thanks for the help. I will use metal.
