Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 19, 2025, 03:59:55 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
Building techniques
(Moderator:
RandySmith
cap strips
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: cap strips (Read 2310 times)
dale gleason
23 supporter
Trade Count:
0
Captain
cap strips
on:
January 30, 2010, 07:55:04 PM »
Here's an idea that I stumbled across, probably everyone already does it this way, I am a slow study, but, here goes.....
"Drumroll, please"
,.......radius your capstrips before you glue them on the ribs!
That's all, folks.
dg
Logged
Russell Shaffer
AMA Member
Trade Count:
0
Admiral
Re: cap strips
Reply #1 on:
January 30, 2010, 08:13:57 PM »
Thanks, Dale. I hadn't thought of it.
Logged
Russell Shaffer
Klamath Falls, Oregon
john e. holliday
25 supporter
Trade Count:
0
Admiral
Re: cap strips
Reply #2 on:
February 01, 2010, 08:50:05 AM »
You mean we were supposed to radius them?
Logged
Shawnee, KANSAS 66203
AMA 23530 Have fun as I have and I am still breaking a record.
Neville Legg
Trade Count:
0
Captain
Re: cap strips
Reply #3 on:
February 01, 2010, 11:07:43 AM »
By radius, I assume you mean round off the edges that the covering will sit on?
Do you do this on the back of the L/E and sheet T/E where it turns in to an open bay as well?
Cheers Neville
Logged
(not) Descartes
Gene O'Keefe
2014 Supporters
Trade Count:
0
Captain
Re: cap strips
Reply #4 on:
February 01, 2010, 11:50:47 AM »
Neville, correct...plus it's recommended to have 90 degree half circles of balsa present at the 90 corners of the
LE / TE sheeting.
Logged
Gene O'Keefe
AMA 28386
dale gleason
23 supporter
Trade Count:
0
Captain
Re: cap strips
Reply #5 on:
February 09, 2010, 06:34:23 AM »
Yes, just to avoid any sharp edges where the covering becomes open bay. dg
Logged
Bootlegger
22 supporter
Trade Count:
0
Admiral
Re: cap strips
Reply #6 on:
February 09, 2010, 09:10:46 AM »
How about radius them over a light bulb to get them to conform to the curve of the ribs also. What do y'all say ??
Logged
8th Air Force Veteran
Gil Causey
AMA# 6964
dale gleason
23 supporter
Trade Count:
0
Captain
Re: cap strips
Reply #7 on:
February 10, 2010, 02:01:56 PM »
Like I said, I'm a slow study. The edge to be radiused I'm refering to is the "length-wise" dimension, like Bob referred to. dg
Logged
FLOYD CARTER
24 supporter
Trade Count:
0
Admiral
Re: cap strips
Reply #8 on:
February 10, 2010, 04:15:28 PM »
I always sand the wing (with cap strips) with a sanding bar. I think this knocks off any edges. My method of glueing cap strips: I lick the top of each cap strip before applying glue to the rib. This causes the cap to bow slightly, better matching the curve of the rib.
Logged
AMA #796 SAM #188 LSF #020
FLOYD CARTER
24 supporter
Trade Count:
0
Admiral
Re: cap strips
Reply #9 on:
February 10, 2010, 10:17:14 PM »
While in the fever pitch of adding cap strips, licking is the most convenient way (well, almost) of making the cap strips wet.
Logged
Bill Heher
Fix-it
2020 supporter
Trade Count:
0
Admiral
I may not always BOM- but I do the re-builds!
Re: cap strips
Reply #10 on:
February 10, 2010, 11:49:28 PM »
When you are licking and zapping the capstrips in place always remember - trim to lenth, lick, CyA, position on rib.
Mixing up the middle 2 steps taste bad and can glue yer tounge to your lip!
Logged
Bill Heher
If it's broke Fix-it
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Building techniques
(Moderator:
RandySmith
cap strips
