Building Tips and technical articles. => Building techniques => Topic started by: dale gleason on January 30, 2010, 07:55:04 PM
Title: cap strips
Post by: dale gleason on January 30, 2010, 07:55:04 PM
Here's an idea that I stumbled across, probably everyone already does it this way, I am a slow study, but, here goes.....
"Drumroll, please" ,.......radius your capstrips before you glue them on the ribs!
That's all, folks.
dg
Title: Re: cap strips
Post by: Russell Shaffer on January 30, 2010, 08:13:57 PM
Thanks, Dale.  I hadn't thought of it.
Post by: john e. holliday on February 01, 2010, 08:50:05 AM
You mean we were supposed to radius them? HB~>
Post by: Neville Legg on February 01, 2010, 11:07:43 AM
By radius, I assume you mean round off the edges that the covering will sit on? ??? Do you do this on the back of the L/E and sheet T/E where it turns in to an open bay as well?
Cheers     Neville
Post by: Gene O'Keefe on February 01, 2010, 11:50:47 AM
Neville, correct...plus it's recommended to have 90 degree half circles of balsa present at the 90 corners of the
LE / TE sheeting.
Post by: dale gleason on February 09, 2010, 06:34:23 AM
Yes, just to avoid any sharp edges where the covering becomes open bay. dg
Post by: Bootlegger on February 09, 2010, 09:10:46 AM
  How about radius them over a light bulb to get them to conform to the curve of the ribs also. What do y'all say ?? #^
Post by: dale gleason on February 10, 2010, 02:01:56 PM
Like I said, I'm a slow study. The edge to be radiused I'm refering to is the "length-wise" dimension, like Bob referred to.  dg :)
Post by: FLOYD CARTER on February 10, 2010, 04:15:28 PM
I always sand the wing (with cap strips) with a sanding bar.  I think this knocks off any edges.  My method of glueing cap strips: I lick the top of each cap strip before applying glue to the rib.  This causes the cap to bow slightly, better matching the curve of the rib.
Post by: FLOYD CARTER on February 10, 2010, 10:17:14 PM
While in the fever pitch of adding cap strips, licking is the most convenient way (well, almost) of making the cap strips wet.
Post by: Bill Heher on February 10, 2010, 11:49:28 PM
When you are licking and zapping the capstrips in place always remember - trim to lenth, lick, CyA, position on rib.
Mixing up the middle 2 steps taste bad and can glue yer tounge to your lip!
