  • August 01, 2025, 10:02:30 PM
Author Topic: Super Tutor Build Progress  (Read 1828 times)
Offline Clay Schmidt
« on: October 03, 2006, 10:22:14 PM »
Here's a little up date on my "Armourized Tutor" project.
The stabs, elevators, and vertical fins are done.  I shaped the elevators and fins using the wire method.  Super easy to do and dead accurate.
Here is my wing at the very beginning.  This is the first time I've tried using rods.
The wing later in the build.  This is probably the straightest rib wing I've ever built.  The rods work well but sometimes they can get in the way.
The bellcrank is installed.  I'm using a 4 inch.  It just fits.
I'm preparing to install the gear blocks here.  They are like the ones Bob Hunt uses in his lost foam wings, basswood and maple.
I have more pictures later.
Clay Schmidt
Offline Richard Grogan
Re: Super Tutor Build Progress
« Reply #1 on: October 04, 2006, 03:00:16 PM »
Hey Clay!
Nice job! are you building 2 planes? Noticed the 2 stabs and rudders. Who makes that wing jig? I see your a SS Tips man. I did them for 20 years and finally quit 1.5 weeks ago! Taste sooo good! :X
How are you going to finish it?
RG
Long Live the CL Crowd!
                  AMA 85745
Offline Ralph Wenzel (d)
« Reply #2 on: October 04, 2006, 03:08:54 PM »
Doggone, Richard, you're supposed to be a photo expert! Don't you recognize a "double exposure" when you see one? <Grin>
Ralph Wenzel
AMA 495785 League City, TX
« Reply #3 on: October 04, 2006, 05:59:26 PM »
Hi Richard,
Yes I am building two of these.  I just got back into C/L last summer after a 30 year lay off and I'm a little rusty.  I thought a backup would be in order in case I swack one into the concrete again. :P
The wing jig is home made.  I got the .065 wall aluminum tubes from McMaster Carr and the aluminum channel I got from onlinemetals.com.  The support blocks that go between the two channels I made from cabinet plywood.  Real simple and it builds a straight wing.
I plan on finishing the wing with Higgins Ink/dope and Polyspan.  The fuselage and tail feathers I am going to glass. For the solid colors,  stripes, and clear I plan on using Dupont.
The Stoggies help me ponder.  I like em but I really need to give them up too. ;D
Clay Schmidt
« Reply #4 on: October 05, 2006, 09:39:08 PM »
Hi Clay,
Looks like you are doing a real good job on building those Tutors.  They should fly real nice!
Bill <><
« Reply #5 on: October 06, 2006, 06:44:20 PM »
Ty,
Yes it is,,,but I seem to always need more than a spare rudder!!!!!!!!!!!!! **)
Clay
Clay Schmidt
