  • July 16, 2025, 09:36:23 PM
Author Topic: CA debonder works great on epoxy  (Read 1871 times)
Offline frank carlisle
« on: August 14, 2010, 01:20:41 PM »
I was gluing hinges on a new plane this morning. Using 30 minute epoxy and managed to get a couple of the hinges glued solid. I scraped away at them a little and was about to give up when I spotted a bottle of Brodak debonder. The only time I ever used debonder before today was to get rid of the fake fingernail glue (ca I think) that Linda spilled in the sink. Well I figured I'd just give it a try on the stuck hinges and just a drop freed them up in about two seconds.
Frank Carlisle
Offline Leester
Re: CA debonder works great on epoxy
« Reply #1 on: August 14, 2010, 04:09:57 PM »
Thanks Frank, that's a good tip.
Leester
ama 830538
« Reply #2 on: August 14, 2010, 04:38:28 PM »
Yer welcome Lee. I tugged on the hinges and they're stuck in there real good. Just a drop of debonder is all it took.
I wish I'd have tried it years ago.
Frank Carlisle
« Reply #3 on: August 14, 2010, 04:52:25 PM »
Frank, you just might have qualified for the most valuable tip of the century!
Will #^ y1 H^^ CLP** HH%% HH%%
« Reply #4 on: August 14, 2010, 05:38:20 PM »
Thank you Will. I was desperate!
Frank Carlisle
Offline ray copeland
« Reply #5 on: August 14, 2010, 08:23:05 PM »
Thanks for a great tip! I have an elevator that the epoxy didn't harden and i ended up pinning the hinges, but they still aren't real free yet as the epoxy must have ran some and is like goo on the hinges. I may try this tonite!!
« Reply #6 on: August 14, 2010, 10:22:26 PM »
Debonder is usually nitromethane.
« Reply #7 on: August 15, 2010, 03:34:41 PM »
In other words, Howard, keep it off the finish!  Thanks for that additional info, this is all great stuff.
Will
« Reply #8 on: August 15, 2010, 04:01:38 PM »
I only used the debonder on the hinges and the epoxy was only an hour or so old. I don't know how it would work on well cured epoxy. Just a drop per stuck hinge was all it took.
Frank Carlisle
Online wwwarbird
« Reply #9 on: August 15, 2010, 10:52:25 PM »
 Howard,
 So I can mix debonder into my fuel for more power? :##
 Thanks for the tip Frank!
« Reply #10 on: August 15, 2010, 11:19:27 PM »
Yes, unless it has acetone or something in it, too, but it might be cheaper just to get a PA .75.
Offline dennis lipsett
« Reply #11 on: August 16, 2010, 03:15:03 PM »
Acetone could be used as an ignition improver. It is/was used in Europe with no nitro fuel in the winter to spice up the fuel.
Dennis
« Reply #12 on: August 16, 2010, 05:48:12 PM »
Used the debonder this afternoon on my sticky hinges, they are now as free as a bird and still glued in the pocket tight!!  Thanks Frank!!   H^^
« Reply #13 on: August 17, 2010, 03:03:14 PM »
Thankyou Ray for confirming that it works. I didn't know if anyone else would get the same results. #^
Frank Carlisle
