  • July 09, 2025, 12:47:23 AM
Author Topic: Building a stab and elevator.  (Read 1073 times)
Offline James Mills
« on: April 26, 2008, 11:54:50 AM »
I'm building a pipe plane and the plans show 1/2" stab and elevator.  The stab is built up from 3/8 which I have but the elevator is shown as 1/2" solid balsa which I don't have.  Can I use 3/8 and have the elevator be a little thinner or is there a method to make a built up elevator?
James
AMA 491167
Re: Building a stab and elevator.
« Reply #1 on: April 26, 2008, 01:39:25 PM »
James, one way with added benefits, is to use the 3/8 and then holow out the center, put ribs in it then skin it with light 1/16. It will be lighter and stronger. This is how I build all my tail surfaces. sounds like the stab is built the same way so just carry on. Dont forget to leave enough meat in the 3/8 to hold the control horn wire though, its a bit tough to do it lol
Offline Greg L Bahrman
« Reply #2 on: April 26, 2008, 08:27:06 PM »
I made the builtup elevator first, then it was suggested I sheet it for better strength which I did. It made a big difference in the stiffness of the elevator. I know you can't see it but the top sheeting on the elevator is at 45 degrees and the bottom sheeting is 90 Degrees to the top surface. Then just a couple of other examples for ya. Marks suggestion is good for lightweight and strong too.
« Last Edit: April 26, 2008, 08:48:39 PM by Greg L Bahrman »
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Offline Leo Mehl
« Reply #3 on: April 27, 2008, 12:33:38 AM »
When I geodeic the ribs in the stab and elevator I do not use any virtical ribs and therefore save some weight. It seem to be strong enough that way, however, I like to sheet the stab for it makes it real strong. <=
« Reply #4 on: April 27, 2008, 11:59:03 AM »
H James,
That top picture is plenty strong.  That is the way Bob Hunt showed me to build elevators and stabilizers. With the stab sheeted, it will work even better.
Bill <><
