Building Tips and technical articles. => Building techniques => Topic started by: James Mills on April 26, 2008, 11:54:50 AM
I'm building a pipe plane and the plans show 1/2" stab and elevator. The stab is built up from 3/8 which I have but the elevator is shown as 1/2" solid balsa which I don't have. Can I use 3/8 and have the elevator be a little thinner or is there a method to make a built up elevator?
James
James, one way with added benefits, is to use the 3/8 and then holow out the center, put ribs in it then skin it with light 1/16. It will be lighter and stronger. This is how I build all my tail surfaces. sounds like the stab is built the same way so just carry on. Dont forget to leave enough meat in the 3/8 to hold the control horn wire though, its a bit tough to do it lol
I made the builtup elevator first, then it was suggested I sheet it for better strength which I did. It made a big difference in the stiffness of the elevator. I know you can't see it but the top sheeting on the elevator is at 45 degrees and the bottom sheeting is 90 Degrees to the top surface. Then just a couple of other examples for ya. Marks suggestion is good for lightweight and strong too.
When I geodeic the ribs in the stab and elevator I do not use any virtical ribs and therefore save some weight. It seem to be strong enough that way, however, I like to sheet the stab for it makes it real strong. <=
H James,
That top picture is plenty strong. That is the way Bob Hunt showed me to build elevators and stabilizers. With the stab sheeted, it will work even better.
Bill <><
