  • July 04, 2025, 07:33:42 PM
Author Topic: Building a Banshee  (Read 2599 times)
Mike Griffin
Building a Banshee
« on: April 18, 2014, 01:32:13 PM »
Just a question for those of you who have built a Banshee.  The kit directions recommend you cut 1 1/2" off the nose.  Do they mean just come back 1 1/2" from the front of the fuselage and cut it off and then cut to adjust where the engine will be mounted?
Re: Building a Banshee
« Reply #1 on: April 18, 2014, 01:58:10 PM »
That's the usual and easiest way.
F.C.
Mike Griffin
« Reply #2 on: April 18, 2014, 09:29:03 PM »
OK.. Thank you Floyd.  I have never had to do that on a profile kit so I did not want to mess it up...
Offline Bootlegger
« Reply #3 on: April 19, 2014, 12:48:27 PM »
 Mike something else I have seen on the forum's is just glue the wing cut out back in the fuse, and move the new cut out about 1-1,.5 ' forward of the old one.
  Gives the same effect..
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #4 on: April 19, 2014, 01:07:22 PM »
Gives a different effect -- it does the same thing to the CG, but gives the airplane more modern "numbers".
Offline Daniel_Munro
« Reply #5 on: June 20, 2014, 04:41:19 AM »
I've just completed my Banshee. It all depends what engine you intend on using. As per the kit I believe it will balance fine with a Fox 35. If you are using a heavier engine then some length needs to come off. I chopped 1.5 inches off and it balanced exactly on the cg with an OS .40fp up front.
I went further with mine and extended the tail 3 inches, increased the span out to 53 inches, increased the stab and elevator span. Also changed the fin and outline of the fuselage. It flies well with these mods, just a shame my OS won't behave a little better.
NZL7396
Online Paul Smith
« Reply #6 on: June 20, 2014, 05:43:54 AM »
I built my first & only Banshee for the 1990 Sig contest.
I cut 2" off the nose and nobody told me to.  It was that or 2 ounces of tail weight.
