  • June 19, 2025, 10:27:05 PM
Author Topic: Struture failure around Stab...  (Read 3041 times)
John Leidle
« on: June 15, 2014, 10:39:40 AM »
   A few of my recent planes ( last 10 years) have cracks in the fillets & around the stab, not all but some, I don't see any difference in how I built the ones the crack & don't crack, My newest plane the Olympus has the stab cracking away from the fuse in a big way. I cant fly it until I remedy the cracking.
  Any help in construction of the fuse & such is welcome. I've built many planes& it isn't in all but seems more frequent than ever & no I'm not building lighter either.
Re: Struture failure around Stab...
« Reply #1 on: June 15, 2014, 11:17:50 AM »
Do you put doublers around your stab opening?  Even minimal strengthening may help, particularly if you arrange the grain to go in a different direction from the main fuselage sides.
I'm not at all dialed in to what people use for your size of plane, but if you let the group know the wingspan & weight of your planes, and the thickness and density of the fuselage sides, that will help, particularly because they can share what they do.
« Reply #2 on: June 15, 2014, 02:27:08 PM »
I know it would look ugly, but 1/4" triangle balsa on the outside, under the stab, provides plenty of strength.
That has been my "fix" whenever the pushrod and clevis doesn't leave enough room for interior doublers.
F.C.
John Leidle
« Reply #3 on: June 16, 2014, 12:28:02 AM »
  Tim, you 've seen most of my planes  Big boy planes 700 squares . I think you guys might have something in the fillet construction.. I've been making them lighter every year ..I also believe I might want to build up in the area.  The Olympus is pretty minimal over the top of the stab.. maybe I should of built it up.. now I have to figure how to save the plane,
« Reply #4 on: June 16, 2014, 08:30:57 AM »
    This is a pretty common problem the "my airplane is 1 ounce lighter so it's 1 ounce better" crew. You just can't take a design approach that was developed for 35-sized planes and 7 lb balsa, put a 60 or more in it, use 4 lb balsa, and expect it to last.
     The problem is flex along the axis of the grain right below the mount. I use a medium 1/32 vertical-grain balsa doublers underneath the stab, and generous fillets to spread the load.
« Reply #5 on: June 16, 2014, 03:39:45 PM »
I use 1/64" ply doublers around the stab. Never had a crack.
John Leidle
« Reply #6 on: June 17, 2014, 08:17:29 AM »
  I have an idea , since I started reducing fillet size in the rear of the plane & that is when the cracking became more common that might be the cause or part of it.
  Thanks everyone, John
« Reply #7 on: June 17, 2014, 09:39:40 AM »
Cross grain balsa under the stab between the fuselage sides.   If enough room do the same on the top side also.  This is on full built up fuselages.   On profile fuselages I use triangle stock or pieces I make my self.
Eric Viglione
« Reply #8 on: June 17, 2014, 10:10:26 AM »
Oddly enough, widening the fuse a little doesn't hurt either. Since I went to Ball-Links, I've got into the habit of sticking a tail post in the back when I pinch the fuse sides together to give me more room for the ball link and the adjustment hatch.
Larger fillets with a good material like SuperFil helps too... and it doesn't matter if it's foam or built up, I always use an inner trailing edge doubler. With modern horns you might not have to notch the stab trailing edge spar, but even so, there is a stress riser there and you probably use the brass horn clips that cut into it as well... a hard balsa doubler thats around 6" X 3/8" X the stab thickness, prolly wont hurt. You also get the added benefit of it not cupping (hopefully) when you apply silkspan...
EricV
John Leidle
« Reply #9 on: June 17, 2014, 09:06:59 PM »
  Thanks Eric.
