  • June 14, 2025, 05:57:28 PM
Author Topic: 3/8 x 1/2 motor mounts for strength.  (Read 1743 times)
Offline Perry Rose
« on: July 27, 2018, 02:20:58 PM »
I use 3/8 x 1/2 aluminum channel, fill it with 1/4 ply and balsa. Then glue it into a crutch. drill the mounting holes, install brass 6-32 (in this case) inserts and butt them up against the channel. 2.4 ounces. Bullet proof.
Re: 3/8 x 1/2 motor mounts for strength.
« Reply #1 on: July 28, 2018, 10:28:29 AM »
Driill holes in the section behind the fire wall and remove more weight.   You can also taper it behind the fire wall. D>K
Online FLOYD CARTER
« Reply #2 on: July 30, 2018, 10:09:18 AM »
You can do the same drilling holes and tapering with hard maple to save weight.  The 1/2" edge of maple provides lots of glueing area to your fuselage doublers.  This is important for transfering engine vibration to the fuselage structure.
« Reply #3 on: July 30, 2018, 01:38:53 PM »
This is a very good idea.  Have you tries making it adjustable for swapping engines?
