  • June 15, 2025, 04:10:17 AM
Author Topic: Brodak Ringmaster  (Read 3657 times)
Offline Harold Brewer
Brodak Ringmaster
« on: September 06, 2017, 11:44:13 PM »
I'm getting ready to glue the wing of my Brodak Ringmaster into the fuselage.  The kit includes an "Optional" plywood stiffener which appears to be a headache to install.  One has to cut a notch into the leading edge, glue in the stiffener, and then glue into the profile fuselage.  Is this extra effort really worth it?
Brew    H^^
Offline Paul Seeley
Re: Brodak Ringmaster
« Reply #1 on: September 07, 2017, 01:25:27 AM »
Hi Harold
Just done a similar thing in mine (without the tongue extension it has to be said) Easy slot the win leading edge though. Slide it into position mark using the fuz slot as a guide, slit with a scalpel and then enlarge the slot with a suitable gouge (I used a flat needle file, but a hacksaw blade would also work)
When fitting glue into the wing first and then slide the wing in (use a slow curing glue such as PVA or epoxy to give a bit of wriggle time) or if you really must use cyano fit it all together dry and then flood the edges with thin stuff so it wicks in. It does add a lot of strength so I'd suggest fitting  :)
Cheers
Offline James Holford
« Reply #2 on: July 13, 2018, 11:27:26 AM »
I dont see why not.. should help a bit..
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Mike Griffin
« Reply #3 on: July 21, 2018, 05:35:09 AM »
I have built somewhere in the neighborhood of 30 Ringmasters within the last few years and have never done this.  I use the kit put out by RSM and it utilizes ad piece of 1/8" strip of plywood that is glued to the inside of the leading edge that runs the length of the 3 center ribs.  The center rib is notched at the front so the plywood piece will slip through it.  I have never had  wing fold doing this.  My personal opinion from what you are showing that Brodak recommends, is overkill.
« Reply #4 on: July 21, 2018, 08:34:14 AM »
      This "T" piece is not intended to keep the wing together.   The intent is to firmly connect the wing to the fuselage at the leading edge, which has been a disastrous weak point on the Ringmaster since it was first kitted in about 1949. The original arrangement could almost be assured to start cracking sometime after you started attempting to start the engine the first time - but before it actually started. The design is terrible and the doubler only contacted the wing for about an inch (just the LE wood), and at least in the original, the material used, specifically luan or mahogany plywood "door skin", was so incredibly weak that there is basically nothing you can do and no glue that would hold this together. Either the glue joint broke, the attachment to the balsa broke, or the doubler itself broke.
        The "T" joiner is intended to put much a structural connection between the wing and fuselage. I don't know what the Brodak instructions say, but the original idea was to build the wing complete, with the "t" sticking out the front of the wing as shown. Then, you glue the wing into the balsa fuselage, where you have cut a corresponding slot. This spreads the load on both the wing and fuse connection. Then, put the plywood doublers over the top of the "T". The doublers are solid and do not have a slot for the "T" to go through, they cover it up.
   The Brodak version appears to cut the slots in the doubler so you can slip it together after you glue the doublers on. That makes it easier to assemble the fuselage since you can put the doublers on flat, and probably OK as long as you use epoxy and fit it up, but it does depend entirely on the glue to hold it, rather than capturing it like the original design. Note also that the doubler goes much further back on the fuselage, reducing the load on the fuse/wing joint compared to the original.
    If you are using a modern engine like a 15FP, 20/25FP or something relatively smooth like a Veco 19bb, etc, at high revs, it may not be absolutely necessary, particularly considering the modern kits use decent material for the doubler (much, much more durable than the door skin material). It doesn't hurt anything and it's not to difficult to deal with. It would be nicer if they made the kit use it by default and cut the slots at the factory, but it's easy enough to do by hand.
      If you are using a vintage engine like a Fox/McCoy 35, it is my considered opinion that it is nearly a *must* to use the "T" joiner, no matter how good it fits, how good the plywood is, and how strong 30-minute epoxy might be, it's still going to shake itself apart in relatively short order. It did it in 1949 and it will still do it today.
    In any case, it doesn't hurt anything and fixes a notorious weak point.
Offline MikeyPratt
« Reply #5 on: July 24, 2018, 11:03:21 AM »
[/quote]
I have to agree with Brett, it was a sorry design to begin with.  Back in the day McCoy’s were all we had that I could afford from my papers route.  The best engine for the RM was a McCoy 29 and with proper care, it would last at least the life of 2 or 3 models.  I learned very early on that the wing & fuse joint needed to be reinforced with fiberglass cloth and resin.  The leading edge “T” connector was tried many years ago, only we captured the “T” sandwiched between the fuse doublers and used a fillet between the fuse and wing.  That seemed to work better but still not a long lasting cure for the problem.
Later, I transitioned to the Super Firecat, Kingpin, Flitesteak, Flying Clowns, and Stuntmaster models but they all had there own problems with weak spots and/or performance issues.  Now with smoother running engines that helped a bunch.
Later,
Mikey
« Reply #6 on: July 30, 2018, 12:22:53 PM »
In the several Ringmasters I have built, I did not use the horizontal ply piece in the wing center.  Instead, I used 1/16" or 1mm ply as a doubler, placed vertically, out to about the 2nd rib.  Similar to spar doublers.  This converts the wing to an enclosed "box" spar wing.
Of course, this requires cutting some ribs into two pieces.  The extra work results in a strong wing without extra weight.
