  • August 05, 2025, 09:13:15 AM
Author Topic: Vector 40  (Read 1849 times)
Offline sadams714441
Vector 40
« on: January 30, 2007, 06:46:17 AM »
need some help mounting the bellcrank in a Vector 40 kit.  The bellcrank that came with the Brodak kit is that a good bellcrank to use?  Also it tells you to put #10 washers top and bottom with soilder, is that the best way or is there some other way ?  Z bend the rods and such to connect the flap horn and the rod to the bellcrank... Is there a better way?
Steve Adams
Offline Leester
Re: Vector 40
« Reply #1 on: January 30, 2007, 12:32:08 PM »
Steve: The method that comes with a Tom Morris set up is probobly the best, wheel collars and fuel tube.
Leester
ama 830538
Re: Vector 40
« Reply #2 on: January 30, 2007, 12:41:08 PM »
I'll give that a try, so no soilder at all then?
Steve Adams
Offline Leester
Re: Vector 40
« Reply #3 on: January 30, 2007, 01:35:22 PM »
Not in this application. When you have it all set up put thread locker on the wheel collar set screw.
Leester
ama 830538
Offline Leester
Re: Vector 40
« Reply #4 on: January 30, 2007, 01:43:50 PM »
As far as Z bending the pushrod, With this plane I think going with C/F pushrods and ball links is well worth it. Go with the best you won't regret it.
Leester
ama 830538
