  • August 01, 2025, 09:59:17 PM
Author Topic: Big Momma METEOR  (Read 6091 times)
Online RC Storick
Big Momma METEOR
« on: February 18, 2007, 07:00:18 AM »
Here is a shot of the Meteor fuse underway. 7 inches accross.
« Last Edit: February 18, 2007, 07:31:37 AM by Robert Storick »
Offline Jim Treace
  • 1979 600 Aerostar N79JT
Re: Big Momma
« Reply #1 on: February 18, 2007, 07:10:21 AM »
Bob:
I missed previous notes. Is that the wing in background to right?
Jim
Jim Treace
Ponte Vedra Beach, FL &
Paris, TN
AMA 855251 "Too soon we grow old...Too late we grow wise"
Online RC Storick
Re: Big Momma
« Reply #2 on: February 18, 2007, 07:17:01 AM »
yes. 60 -61 inch span 1 inch forward sweep in the TE.
Online RC Storick
Re: Big Momma
« Reply #3 on: February 18, 2007, 07:22:16 AM »
One of the biggest reasons I did this build was to show how you can build anything you can see. These airplanes are just a store mannequin. You have a set of basic numbers that will work. The clothes you hang on those numbers are up to you. You are only limited by your imagination. You do not need to work off plans just numbers and your brain.
Offline Clayton Smith
Re: Big Momma METEOR
« Reply #4 on: February 18, 2007, 10:05:04 AM »
Sparky, you are so right about imagination and visualizing your goals.
Here are some construction photos of a Golden Age Racing Laird-Turner Meteor Special.  Scale "Coke Bottle" fuselage with 60 stringers behind trailing edge.  36 inch span and 5.5 inch fuselage cross section.  Rossi .40 power.
Clayton Smith
Clayton Smith
AMA 16879
High Point, NC
Online RC Storick
« Reply #5 on: February 18, 2007, 10:27:08 AM »
Very nice. This must be a scale plane. Mine will not be that scale like as is has to fly the pattern and I don't think I could make those numbers work.
Offline frank carlisle
« Reply #6 on: February 18, 2007, 10:49:46 AM »
Do you have a picture of the full scale model of this plane Sparky? I'd like to see where you're going here.
Frank Carlisle
Online RC Storick
« Reply #7 on: February 18, 2007, 12:09:29 PM »
 Here is a shot
For more photo's look here  http://oldbeacon.com/plans/resource4/laird-turner_ltr-14_meteor.htm
« Last Edit: February 18, 2007, 02:10:02 PM by Robert Storick »
« Reply #8 on: February 18, 2007, 12:34:24 PM »
Nice subject.............I'll be clicking on often. Thankyou
Frank Carlisle
Online RC Storick
« Reply #9 on: February 18, 2007, 01:06:37 PM »
Formers made. I will now move onto mold bucks.
« Reply #10 on: February 18, 2007, 01:12:11 PM »
I know you're busy.............but, how did you go about determining the shape, size and location of the formers?
Frank Carlisle
Online RC Storick
« Reply #11 on: February 18, 2007, 01:16:10 PM »
I use the tried and tested method of TLAR (That Looks About Right) I laid it out on paper to get the Center line and then added my numbers. Got a compass and determined how fat the fuse would have to be to hide the engine and pipe with the TL still in the center. I then laid out the fuse sides and set the first 3 formers. The rest is done in the TLAR method. I hope this helps.
In the videos I will explain a little on how this works. Just like when I did my S6B I am tired of building the same old plane everyone has. So why not design something new?
« Last Edit: February 18, 2007, 02:11:16 PM by Robert Storick »
« Reply #12 on: February 18, 2007, 02:08:31 PM »
Gotta love fat boy fuselages.
« Reply #13 on: February 18, 2007, 02:09:06 PM »
I get it............
Take a pic of each step please.
Frank Carlisle
Offline Richard Grogan
Re: Big Momma
« Reply #14 on: February 18, 2007, 02:19:07 PM »
Right on Robert! Seems you have the same philosophy as "Big Daddy" Ed Roth!!
Long Live the CL Crowd!
                  AMA 85745
Offline Rudy Taube
  • Ret Flyboy
« Reply #15 on: February 18, 2007, 11:48:57 PM »
Hi Robert,
We all admire, and envy, your beautiful, and fast work. That will be one very impressive CL plane when you set it down in the front row at a contest! :-)
Have you considered using a radial engine to help make the numbers work? Saito makes a nice 3 cylinder that may provide the nose weight you need. The power may not be enough to make up for it's weight, but it sure would sound sweet! And more "cu. in." is almost always better than lead in the nose! ;-)
http://www.horizonhobby.com/Products/Default.aspx?ProdID=SAIE090R3
By the time you add up the wt. of your big engine, + header+ pipe+ extra 2 stroke fuel, the radial should only be about 6 oz more?? But it would all be up front, on that big, beautiful, round, short nose.
Rudy
AMA 1667
Online RC Storick
« Reply #16 on: February 19, 2007, 09:34:37 AM »
Hi Robert,
I will not need extra weight in the nose. As you see in the next photo I am lightining the fuse every way I can. I will apply skin and sand the outside then remove the skin and sand the inside to a even 1/32 or less, all the way around.
« Last Edit: February 19, 2007, 02:32:14 PM by Robert Storick »
« Reply #17 on: February 19, 2007, 05:51:48 PM »
Well, looks at this way. There will be plenty of room for a tank.
Online RandySmith
« Reply #18 on: February 19, 2007, 08:54:15 PM »
Hi Robert,
LOL Rudy
You may want to look at the specs   .....
Bore: 20mm (0.78 in)
Stroke: 16.0mm (0.63 in)
Cylinders: Three
Engine (Only) Weight: 29.98 oz
That is a  30 ounce engine  bare  that is  18 ounces more than a  75,,Robert would need about a 1\2 pound of  lead  in the tail  for that  beast   #^ #^ #^ #^ #^ LL~ LL~ LL~
Randy   LL~
Offline Mike Palko
« Reply #19 on: February 19, 2007, 09:16:04 PM »
LOL Rudy
Cylinders: Three
Randy   LL~
   It's not to late to shorten the nose!!!!!  ;D
   Robert this is a great project! What do you think it will do in the wind with all that side area? Do I see a 2007 NATS entry???  ;) The wind has been light and predictable in the past few years.......  LL~
Offline Rudy Taube
  • Ret Flyboy
« Reply #20 on: February 19, 2007, 10:14:29 PM »
Mike, and Randy,
Yes, there was a bit of tongue in my cheek, and wishful thinking as well. ;-)
Randy, you were supposed to say: "it weighs ONLY 30 oz." :-)
I think it would still balance OK with the scale short nose, BUT it is very hard to match the power to weight ratio of one of Randy's big 2 stroke engines on a pipe. .... Maybe using 60% Nitro for "one" cool sounding flight might work?  LL~
I like Radial engines. They sound good, and look like an engine should look. I was very lucky as a young pilot to get a few thousand hours in round motor planes, just before they all disappeared from commercial flight, and we were forced to fly boring jets.
I try to put in the ;-) to show that I may be kidding, and I hope people understand this. I guess you guys did. ..... I'm glad I was able to provide a LOL for Sparky's readers.    **)
« Last Edit: February 25, 2007, 04:43:14 PM by Rudy Taube »
Rudy
AMA 1667
« Reply #21 on: February 21, 2007, 07:13:22 PM »
You're working on the bucks, right Sparky?
Frank Carlisle
Offline Joe Gilbert
« Reply #22 on: February 23, 2007, 12:50:33 AM »
What a great project, saw it at Oshkosh couple years ago very impressive plane. A piece of the Golden Age of Racing.
Joe Gilbert
« Reply #23 on: February 23, 2007, 03:50:00 PM »
Really neat Robert; I bet it won't fly any different than a skinny fuse. I built a scale Spinks Acromaster R/C one time that had a 6" wide fuse. I thought it would be very draggy, but that thing seemed to have less drag than some of my skinny planes.
« Reply #24 on: February 28, 2007, 07:55:58 AM »
Where's the "Big Momma"??  Withdrawals here, haven't seen anything new in a while......... you got the flu, Sparky??  **)
Bill <><
« Reply #25 on: February 28, 2007, 11:08:24 AM »
Bill, I imagine those molding bucks are taking a bit of time.  :)
