  • August 01, 2025, 10:09:56 PM
Author Topic: Bell crank hole  (Read 1984 times)
Offline sadams714441
Bell crank hole
« on: February 12, 2007, 01:13:25 PM »
Which hole should i use when using a Brodak bellcrank on a Vector 40, the bellcrank that comes with it has 3 holes
Steve Adams
Offline Jim Morris
Re: Bell crank hole
« Reply #1 on: February 12, 2007, 02:08:29 PM »
I would use the most inner hole Steve.
Online RC Storick
Re: Bell crank hole
« Reply #2 on: February 12, 2007, 02:40:14 PM »
You want it as closest to the same distance as the control horn hole you can get. That gives you 1 to 1 .
Like on a 4 inch bell crank set up. The line spacing is 4 inch as the bell crank. The flap horn is 1.25 and the hole in the bell crank is 15/16 off pivot. This slows the controls down a little. I hope I have explained this well enough? I would put it on the outer most hole. You can always narrow up the line spacing to slow the controls down.
Re: Bell crank hole
« Reply #3 on: February 12, 2007, 06:22:33 PM »
Robert
So use the outer most hole to make it 1to 1 ?  If you use the middle hole as it shows on the plans what does that make it?
Steve Adams
Online RC Storick
Re: Bell crank hole
« Reply #4 on: February 12, 2007, 06:26:50 PM »
Robert
You must move the bell crank farther to get the same action the closer to the pivot you move the hole. If you are using a 3 inch bell crank and the second hole would probably act like a 4 inch bell crank. 6 to 1 half a dozen to the other. You can always move line spacing closer at the handle.
Re: Bell crank hole
« Reply #5 on: February 12, 2007, 06:30:09 PM »
So use the outer most hole and which hole on flap horn and which one on tail
Steve Adams
Offline Alan Buck
Re: Bell crank hole
« Reply #6 on: February 12, 2007, 06:40:41 PM »
HI STEVE    I used the middle hole in the bellcrank upper hole on flaps and middle hole for elevator is on a vector arc hope this helps you    ALAN
ALAN E BUCK
Re: Bell crank hole
« Reply #7 on: February 12, 2007, 06:57:52 PM »
thanks how did it work out for you, I have one that I,am working on. But not ARC
Did you use ball links on bellcrank and horns
Steve Adams
