  • July 31, 2025, 11:15:12 AM
Author Topic: Barrel Hinges?  (Read 2261 times)
Offline Joe Messinger
Barrel Hinges?
« on: September 11, 2006, 07:20:06 AM »
Hello,
I read about the use of "Barrel Hinges" for flap and elevator attachment but  I am not sure just what they are.  I've looked through Tower's hinge inventory and find nothing listed.  I have also checked Brodak's catalog and there's no barrel hinges there.
Perhaps someone can explain just what a barrel hinge is?
Joe
Joe Messinger
Re: Barrel Hinges?
« Reply #1 on: September 11, 2006, 07:21:44 AM »
Hello,
Joe
Hi Joe,
That's the term that was given to the regular nylon hinges that are joined by wire pins many years ago in a Galaxay far, far away!   n~
Bill <><
Offline Tom Dugan
Re: Barrel Hinges?
« Reply #2 on: September 11, 2006, 07:51:50 AM »
I thought this was a "Barrel Hinge."
Offline Ron King
Re: Barrel Hinges?
« Reply #3 on: September 11, 2006, 09:30:03 AM »
We have always just called those "hinge points", since that's what Robart named them years ago. They work great but are a royal PITA to get aligned properly. Not only do you worry about vertical and horizontal alignment, they can also rotate slightly and drive you nuts as the epoxy sets up.  **)
Ron King
AMA AVP District 4
Wannabe Stunt Pilot since 1963
 Amateurs practice until they get it right; Pros practice until they cannot get it wrong.
Offline RC Storick
Re: Barrel Hinges?
« Reply #4 on: September 11, 2006, 09:41:16 AM »
I would not use this type hinge if I were you!
