Building Tips and technical articles. => Building techniques => Topic started by: Joe Messinger on September 11, 2006, 07:20:06 AM
Hello,
I read about the use of "Barrel Hinges" for flap and elevator attachment but I am not sure just what they are. I've looked through Tower's hinge inventory and find nothing listed. I have also checked Brodak's catalog and there's no barrel hinges there.
Perhaps someone can explain just what a barrel hinge is?
Joe
Hello,
Joe
Hi Joe,
That's the term that was given to the regular nylon hinges that are joined by wire pins many years ago in a Galaxay far, far away! n~
Bill <><
I thought this was a "Barrel Hinge."
We have always just called those "hinge points", since that's what Robart named them years ago. They work great but are a royal PITA to get aligned properly. Not only do you worry about vertical and horizontal alignment, they can also rotate slightly and drive you nuts as the epoxy sets up. **)
(http://stunthanger.com/smf/index.php?action=dlattach;topic=1796.0;id=1842;image)
I would not use this type hinge if I were you!
