  • July 12, 2025, 09:58:30 AM
Author Topic: balance point  (Read 1022 times)
Offline roger
balance point
« on: May 26, 2008, 06:03:51 AM »
 VD~ive got the p-51-b from brodak , the plans say the balance point is 1/2 an inch back from the leading edge, but it still seems very nose heavy at that point. should i ad some weight to the back?. then again the plans say [it should slightly nose heavy] well how much is slightly??
roger
Offline Leester
Re: balance point
« Reply #1 on: May 26, 2008, 07:24:09 AM »
Roger: What engine are you using ?? Slightly to me is just beyond balancing and it tips down. Remember balance with no fuel in the tank.
Leester
ama 830538
Offline roger
Re: balance point
« Reply #2 on: May 26, 2008, 08:30:31 AM »
im useing a 40 size motor  and tank has no fuel
Offline Jim Oliver
Re: balance point
« Reply #3 on: May 26, 2008, 08:39:49 AM »
Hi Roger,
You probably know this already----
Nose heavy planes usually survive the first flights in fine condition #^,  tail heavy planes may not survive at all :'(.
Cheers,
Jim
Jim Oliver
AMA 18475
Offline roger
Re: balance point
« Reply #4 on: May 26, 2008, 08:58:04 AM »
thanks guys H^^
