  • June 18, 2025, 05:11:39 AM
Author Topic: fiber glss push rods  (Read 3270 times)
Offline Bootlegger
« on: April 25, 2016, 04:45:10 PM »
  What size and where did you get the f/glass push rods that you use? I am thinking about something with about 1/8" inside dia.
 Sure could use some suggestions..
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: fiber glss push rods
« Reply #1 on: April 25, 2016, 04:48:04 PM »
The carbon fiber push rods that I use had been coming from an archery shop that sells "rebuildable" arrows for $1 a pop.  Lately, my LHS has been stocking them for about $4 a pop, but it doesn't require going 50 miles out of my way.
« Reply #2 on: April 25, 2016, 05:11:01 PM »
You can purchase CF pushrods from Stunt Hanger Hobbies, AND the metal fittings that attach to the ends.
Offline George Truett
« Reply #3 on: April 25, 2016, 05:40:48 PM »
Darrol Cady has been supplying the R/C Pylon guys with carbon rods for quite a few years now.  He has everything you need for 4-40 pushrods.   http://www.darrolcady.com/Carbon_Fiber/carbon_fiber.htm
Offline Mike Griffin
« Reply #4 on: April 25, 2016, 06:27:39 PM »
Offline David Hoover
« Reply #5 on: April 25, 2016, 06:31:03 PM »
Also Central Hobbies has them.  https://www.centralhobbies.com  Just follow the link for "Control Linkage" and you'll find more than you can ever use.
Best, Hoovie
« Reply #6 on: April 26, 2016, 09:27:05 AM »
got some old helicoptor ones cheapish .
Fishing rod Manufacturers have real C.F. , may have offcasts .  :P LL~
Duno if real ace comp. arrowshafts are real comp. grade C.F. ?? in which case an arrowshop .
Then , there might be someone making Arrow Shafts ! :! if the entire West hasnt sold out to cheap forign imports through abolishing tarrifs ,
WHY , I remember ./ . . . .  >:( ;)
 H^^
« Reply #7 on: April 26, 2016, 02:12:34 PM »
You can get them from Central Hobbies online, also. Ends, too.
