  • July 05, 2025, 11:13:15 AM
Author Topic: Attaching alum. pads to motor mounts ?  (Read 2070 times)
Offline Rob Killick
« on: December 01, 2009, 06:02:22 PM »
Hi ,
Seeing how I'm on a roll , I may as well ask this one ...
How or what is a good way to attach the aluminum pads to the maple motor mounts ?
One set I have done , was to daedo the maple mounts and use #4 X 1/2" wood screws to attach the 1/8" thick aluminum pads to the mounts(with counter sunk holes) . Then , I can drill through holes in the aluminum pads and maple mounts and "Tee nut" them , opposite the pads .
What I'd like to know , is it all right to epoxy the pads to the maple mounts , for extra security ?
I'm sure I've asked this before , but I think the subject was lost in the last site "crash" .
Thanks ,
Rob Killick
Rob Killick , MAAC 33300
Offline Leester
Re: Attaching alum. pads to motor mounts ?
« Reply #1 on: December 01, 2009, 07:01:20 PM »
Rob I usually just tack them in place with thin CA. If the screws and engine bolts don't hold'em  ??? ??? ???
Leester
ama 830538
Online Clint Ormosen
« Reply #2 on: December 01, 2009, 07:49:56 PM »
Ditto.
 Rob, I think you might be making it much harder than it needs to be. I could see doing it your way if you intended to try several different engines in the model. But if not, keep it simple.
Offline Rob Killick
« Reply #3 on: December 01, 2009, 08:00:05 PM »
Thanks fellas ,
I see what you mean by keeping it simple ...
More than anything , I was figuring that the epoxy , between the alum and maple , may add as a vibration dampener and fill any imperfections in the wood , left by the saw teeth ?
Thanks again ,
Rob K.
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #4 on: December 02, 2009, 02:27:42 AM »
The trick to getting epoxy to stick to aluminum is smear a little on then sand it with the epoxy. This breaks the oxidation and lets the epoxy get to bare metal. If you sand it before applying epoxy it will oxidize before you can get anything on it. Same reason aluminum can't be soldered with normal methods.
« Reply #5 on: December 02, 2009, 08:38:17 AM »
   Yes - as long as you skip the screws. There's no load on the pads and for years I just left them loose. I think the last thing you want to do is put a screw into the wood. All that does is leave a weak spot that you don't need.
Offline Greg L Bahrman
« Reply #6 on: December 02, 2009, 08:49:20 AM »
I have been applying thin CA to the motor mount (wood) area. Let it soak in and then wipe clean. I do it a couple of times. I also put CA in the mounting holes to seal them before I put the t-nuts in the farside. Then before I mount the engine I apply Silicone between the wood and the aluminum plates. I always screw the plates down. Wipe off any excess sealant. As Brett says probably not needed and the extra screws are always a place for the oil to migrate to. Although I've never had a problem. The rest of the compartment gets brushed sealed with resin.
« Last Edit: December 02, 2009, 09:14:44 PM by Greg L Bahrman »
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Offline Rob Killick
« Reply #7 on: December 02, 2009, 08:40:49 PM »
Hi ,
I just wanted to say Thank you to  those who responded to my question(s).
I'm doing this hobby without the help of any "control line Gurus" in my general area , so this site and the people here are a Godsend  y1
Thanks again ,
Rob Killick
« Reply #8 on: December 03, 2009, 01:37:45 PM »
I use a 1/2" square mount and a 3/8 square engine "pad". The engine bolts to the pad and the pad bolts to the maple mounts. It's very stable (though it does take some mill work) and allow new pads for different engines, whatever.
Offline Ward Van Duzer
« Reply #9 on: December 18, 2009, 08:52:08 AM »
I do not mill the pads into the mounts. (Weakens mounts and creates a shear line) Screw the 1/8" or 3/32nd aluminum pads down with little flat head wood screws. (3/8" L. No glue...theyr'e not going anywhere) This also provides a little more vertical adjustment for your fuel tank!
W.
