  • July 13, 2025, 12:24:31 AM
Author Topic: Attaching flap/elev. horns ...Need lessons  (Read 1760 times)
Offline Rob Killick
« on: November 30, 2009, 09:36:59 PM »
Hi ,
Okay , here goes ...
Are flaps epoxied to the flap horns , or can they be left as is and slid onto the flap horn ?
I can see when using "Lucky boxes" ,  epoxy should not be used . What if I use bass wood "clips" ?
I guess my second question should be ...
If I'm going to insert the wire flap horn to a plain balsa flap should I epoxy , or not ?
Thanks ,
Rob Killick
« Last Edit: December 01, 2009, 02:40:30 PM by Rob Killick »
Rob Killick , MAAC 33300
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Attaching flap/elev. horns ...Need lessons
« Reply #1 on: December 01, 2009, 01:25:14 PM »
As you stated, epoxy everything except lucky boxes.. I have epoxied horns directly into balsa flaps on several ships without issues.
Offline Rob Killick
« Reply #2 on: December 01, 2009, 02:42:02 PM »
Hi Bob ,
Thanks for the help .
I appreciate your time and help  y1
All the best ,
Rob Killick
Offline Dick Pacini
« Reply #3 on: December 01, 2009, 03:43:05 PM »
I have been away too long.  What is a lucky box? HB~>
AMA 62221
Offline Bob Reeves
« Reply #4 on: December 01, 2009, 04:14:33 PM »
A plywood box that just fits the control horn wire. It allows the wire to move sideways for tapered, dihedral or swept wings. Can't remember how it got it's name.. I used lucky boxes on both the flaps and elevators of the FJ-4 carrier airplane I'm building. The wing is both swept and has dihedral, the elevators are swept.
http://stunthanger.com/smf/index.php?topic=14390.0
Offline Ralph Wenzel (d)
« Reply #5 on: December 01, 2009, 05:14:42 PM »
"Lucky Box" got it's name from Royal "Lucky" Pyatt, the developer. RSM includes Lucky Boxes with many of their excellent kits.
Ralph Wenzel
AMA 495785 League City, TX
« Reply #6 on: December 01, 2009, 06:07:55 PM »
If you use 3/32 horns, 1/8x1/4 square brass tubing works great for Lucky boxes.
Don
Offline Ward Van Duzer
« Reply #7 on: December 19, 2009, 12:01:38 PM »
After drilling the horn wire hole pin prick the areas above and below the tunnell. Then wick thin CA into the hole and the outside pinpricks. Sand and fill, or cover with cloth hinges. Open up with a hand drill if needed. Has worked as good or better for me than plywood sandwiches when "tweaking". And it's invisable! On straight trailing edges, epoxy the horn wire.
W.
