  • July 13, 2025, 09:41:04 AM
Author Topic: fin and stab  (Read 1495 times)
Offline Jack Mulinix
  • AMA 917877
fin and stab
« on: December 04, 2011, 03:23:37 PM »
Building a profile p-40. Any pros or cons to gluing fin and stab on before gluing wing in? I normally go wing, stab, then fin, but somehow got tail feathers done before wing. thanks Jack
Re: fin and stab
« Reply #1 on: December 04, 2011, 03:41:44 PM »
You , or I should say I, don't want to glue the tail feathers on until the wing is in and straight because the stab needs to referenced to the wing as for accuracy.  Measure from a place on the wing and equal distance from the fuse on each side and line the tips of the stab up that way.
« Last Edit: December 04, 2011, 06:43:31 PM by Will Hinton »
Re: fin and stab
« Reply #2 on: December 04, 2011, 04:37:31 PM »
Pretty much what Brother Will said, plus I will probably break the tail if I install it before the wing is in.
Big Bear
  • AMA 917877
Re: fin and stab
« Reply #3 on: December 04, 2011, 05:36:05 PM »
Thanks guys for the good call. Was sitting here watching football and playing with balsa thinking I could probably glue something, But  didn't feel right. Thanks Jack
Re: fin and stab
« Reply #4 on: December 04, 2011, 07:38:27 PM »
Jack, glue parts on the wing dude,, lol
  • AMA 917877
Re: fin and stab
« Reply #5 on: December 04, 2011, 08:11:37 PM »
Mark, I want to, but that D thing has me stalled. Trying to get a grip on it. Just can't seem to. Then theres the tip thinggy.
Re: fin and stab
« Reply #6 on: December 04, 2011, 08:32:32 PM »
did you ever call Pat? heck give me a call dude,, we can getcha going again one way or another,,
  • AMA 917877
Re: fin and stab
« Reply #7 on: December 04, 2011, 08:35:45 PM »
rodger that
Offline Russell Shaffer
Re: fin and stab
« Reply #8 on: December 05, 2011, 06:09:33 AM »
Which P-40 are you building?  I assume it's one of Pat's many?
Russell Shaffer
Klamath Falls, Oregon
  • AMA 917877
Re: fin and stab
« Reply #9 on: December 05, 2011, 01:11:52 PM »
Hi Russell, hows things in Or? It's a brodak p-40. So far its going ok.
Offline Serge_Krauss
Re: fin and stab
« Reply #10 on: December 05, 2011, 01:19:02 PM »
I usually do the vertical stabilizer with the profile fuselage before inserting the wing or horizontal stab, since it is easier to attach accurately, fillet, blend, and sand to a finish, without the other things being in the way or getting damaged. In fact, I build it as part of the profile structure. The fuselage is ready for color by the time I insert the wing. Filleted areas are roughed and not so ready, and through my many crashes, I have yet to break off a vertical stab or damage any fillet - not even a crack. My fillets are epoxy/microballoons or balsa.
SK
