Building Tips and technical articles. => Building techniques => Topic started by: Jack Mulinix on December 04, 2011, 03:23:37 PM
Title: fin and stab
Post by: Jack Mulinix on December 04, 2011, 03:23:37 PM
Building a profile p-40. Any pros or cons to gluing fin and stab on before gluing wing in? I normally go wing, stab, then fin, but somehow got tail feathers done before wing. thanks Jack
Title: Re: fin and stab
Post by: Will Hinton on December 04, 2011, 03:41:44 PM
You , or I should say I, don't want to glue the tail feathers on until the wing is in and straight because the stab needs to referenced to the wing as for accuracy.  Measure from a place on the wing and equal distance from the fuse on each side and line the tips of the stab up that way.
Post by: Bill Little on December 04, 2011, 04:37:31 PM
Pretty much what Brother Will said, plus I will probably break the tail if I install it before the wing is in.
Big Bear
Post by: Jack Mulinix on December 04, 2011, 05:36:05 PM
Thanks guys for the good call. Was sitting here watching football and playing with balsa thinking I could probably glue something, But  didn't feel right. Thanks Jack
Post by: Mark Scarborough on December 04, 2011, 07:38:27 PM
Jack, glue parts on the wing dude,, lol
Post by: Jack Mulinix on December 04, 2011, 08:11:37 PM
Mark, I want to, but that D thing has me stalled. Trying to get a grip on it. Just can't seem to. Then theres the tip thinggy.
Post by: Mark Scarborough on December 04, 2011, 08:32:32 PM
did you ever call Pat? heck give me a call dude,, we can getcha going again one way or another,,
Post by: Jack Mulinix on December 04, 2011, 08:35:45 PM
rodger that
Post by: Russell Shaffer on December 05, 2011, 06:09:33 AM
Which P-40 are you building?  I assume it's one of Pat's many?
Post by: Jack Mulinix on December 05, 2011, 01:11:52 PM
Hi Russell, hows things in Or? It's a brodak p-40. So far its going ok.
Post by: Serge_Krauss on December 05, 2011, 01:19:02 PM
I usually do the vertical stabilizer with the profile fuselage before inserting the wing or horizontal stab, since it is easier to attach accurately, fillet, blend, and sand to a finish, without the other things being in the way or getting damaged. In fact, I build it as part of the profile structure. The fuselage is ready for color by the time I insert the wing. Filleted areas are roughed and not so ready, and through my many crashes, I have yet to break off a vertical stab or damage any fillet - not even a crack. My fillets are epoxy/microballoons or balsa.
SK
