Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
August 01, 2025, 09:08:58 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
Building techniques
(Moderator:
RandySmith
Adjustable leadout guides The final chapter
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Adjustable leadout guides The final chapter (Read 1809 times)
Keith Spriggs
Trade Count:
0
Captain
on:
December 28, 2006, 04:29:06 PM »
Adjustable Leadout Guides
Max line spacing 2 inches
Min. line spacing 3/8 inch
Guide I. D. .052
Weight 1/10 oz.
Logged
Mark Scarborough
2015
Trade Count:
0
Admiral
Re: Adjustable leadout guides The final chapter
Reply #1 on:
December 28, 2006, 10:47:57 PM »
very nicely done, I like it lots. now when are you going into production?
how much time do you have invested do you recon? Just being nosy
probably make a fortune huh,,,hehehe
Logged
Steve Helmick
24 supporter
Trade Count:
0
Admiral
Reply #2 on:
January 01, 2007, 05:58:03 PM »
Now you're talkin'! You really don't need individually adjustables. A single slider with one screw would save weight. Be sure to make the screw long enough that you can put a goober on the threads with a pair of diagonal wire cutters. That way, the screw can't fall out, which can be fatal. Uh-oh, Robert done put more smiley face icons for me to use.
Logged
In 1944 18-20 year old's stormed beaches, and parachuted behind enemy lines to almost certain death. In 2015 18-20 year old's need safe zones so people don't hurt their feelings.
Keith Spriggs
Trade Count:
0
Captain
Reply #3 on:
January 01, 2007, 10:55:07 PM »
Quote from: Steve Helmick on January 01, 2007, 05:58:03 PM
I made it with two individual guides as it was much easier and also because I figured that the weight of the additional bolt would not be much different than the aluminum to connect them together. Here is a picture of the socket head cap screw that I used. You will notice that it is very small. It is a 1-72x 1/4 inch. However it has a tensile strength of 260 pounds. It is long enough to upset the threads on the back side. The plate that the screw goes into is steel and it has about 1/2 again as many threads as 1/72 nut. I snugged them up and could not pull them apart. There is a brass bushing that surrounds the screw where it goes through the slot in the slide. This makes it very easy to adjust. It is extremely small. .120 OD
.080 ID and .035 Thick.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Building techniques
(Moderator:
RandySmith
