  • July 05, 2025, 11:09:08 PM
Author Topic: Adjustable Ball Link Control Horn Questions  (Read 1161 times)
Offline Peter Hess
« on: October 08, 2009, 10:07:35 AM »
First, I am giving serious thought to using To Morris Adjustable Control Horns on my next couple of planes.  Other than being sure to use the slider nut,  do you have any advice or warnings about using them?
Second, leaving aside the question about whether both are necessary, is there any reason not to use a Tom Morris Adjustable Ball Link Control Horn on both flaps and elevators?
Thanks in advance for your comments and suggestions.
Peter Hess
Canton, CT
AMA 485070
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Adjustable Ball Link Control Horn Questions
« Reply #1 on: October 09, 2009, 01:41:34 PM »
Nope they work great and the only control system I use in anything I'm serious about. Might also check out his reverse thread insert for the elevator.
Usually not necessary, complicates the flap connections and you would have to include some sort of access for adjustment.
Offline Peter Hess
« Reply #2 on: October 09, 2009, 03:46:43 PM »
Bob:
Thank you for your clear and concise answers to my questions.  However, I now have another question.  I am unfamiliar with the function of/advantages of the "reverse thread insert for the elevator."  I would greatly appreciate it if you would enlighten me.  Thanks in advance for your further help.
Peter Hess
Canton, CT
AMA 485070
Offline Bob Reeves
« Reply #3 on: October 09, 2009, 04:00:40 PM »
The reverse thread insert makes a turnbuckle out of the elevator push rod. It has a hex part that allows you to use a small wrench to adjust the pushrod length without having to disconnect anything. Some may have done it but I've never built a flapped ship that didn't require a tweak of the pushrod during the trimming process.
Offline Peter Hess
« Reply #4 on: October 09, 2009, 05:44:06 PM »
Thanks, again, Bob.  I understand.  It sounds as though it would be very useful.
Peter Hess
Canton, CT
AMA 485070
