  • August 01, 2025, 09:00:41 AM
Author Topic: ADJ. ELEV. WINDOW  (Read 3765 times)
Offline Greg L Bahrman
ADJ. ELEV. WINDOW
« on: May 22, 2006, 10:19:18 PM »
Progress continues. Adjustable elevator window completed.  <=
« Last Edit: July 20, 2006, 08:47:50 PM by Greg L Bahrman »
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Re: ADJ. ELEV. WINDOW
« Reply #1 on: May 24, 2006, 06:49:51 AM »
Nice touch, Greg.  y1
Offline airbrush
« Reply #2 on: May 24, 2006, 09:05:31 PM »
OK, I'll bite.
What is it for?
james
« Reply #3 on: May 24, 2006, 09:31:30 PM »
James,
The attached picture is of an adjustable Elevator Horn. Once closed inside the ship it is not adjustable. A removable window allows you to loosen the screw and adjust the position of the control rod on the horn to a position that will achieve maximum performance. Sorry for the poor photo. The window is a small removable piece of plywood that is held in place with one screw and is positioned so that there is easy access to the screw on the control horn. The window is to be removed at the field during the trimmimg process and replaced until the best position/performance is reached. The closer the rod is to the pivot the more elevator travel and the farther away from the pivot the less the elevator travel.  y1   :!
Simi Valley, Ca.
Offline airbrush
« Reply #4 on: May 25, 2006, 10:25:49 PM »
Now I get it!!!
I've never thought about that before, it's a great idea. Thanks for sharing.
james
Offline Dennis Pedersen
  • ACE
« Reply #5 on: May 26, 2006, 06:52:13 PM »
You also adjust the neutral between flap and elevator by lengthening or shortening the elevator pushrod.I install a lefthand thread on one end so you can just rotate the rod .
Dennis Pedersen
Alberta Canada
« Reply #6 on: May 27, 2006, 10:32:24 AM »
There are many methods to do this. One is the moving window. I've seen this idea a lot. Others include a removable piece that's held on by numerous mechanisms; screws, blind nuts, etc.
Here's mine. I like it a lot.
Offline Oregon_Flyer
  • ACE
« Reply #7 on: May 27, 2006, 03:18:25 PM »
Randy,
Way cool.  Know you've got a nifty camera so how about an enlarged close up with some measurements and how to steps.  And I thought my access doors were good.   j1
Marv
« Reply #8 on: May 27, 2006, 11:58:25 PM »
Marv,
I'll take some pictures when I do this next one. I'm allready deep into the next project. When I get to this part (comes pretty early in the process when building a fuselage), I shoot some pics and post them with a description. It's not really very hard. Should be doing this tomorrow, actually. Or the next day.
« Reply #9 on: May 30, 2006, 01:39:10 PM »
Marv,
Well, it's done. I took about 15 pictures. Came out so well, I think I'll send it to Stunt News.
  • ACE
« Reply #10 on: May 31, 2006, 07:31:39 AM »
Randy,
Hmmmm, I clicked on "done" since the pic's were a no show thinking you had been back
to your tricks again  :-X, nada.  Wait, the treetop flier is the secret link!  Not, bummer.
Do I need special glasses to view the results? Perhaps a littel heat  f~  f~  **)
Marv
« Reply #11 on: May 31, 2006, 10:35:03 PM »
Hey, read the new Stunt News agreement. If I post them here, Tom will get mad at me.    #^
