  • August 01, 2025, 09:03:29 AM
Author Topic: Block coats  (Read 2203 times)
Online RC Storick
Block coats
« on: May 31, 2006, 08:13:38 PM »
I tried something diffrent (at least for me). I painted 2 coats of clear with the Zinc in it. Then I went to the primer I usally use  (NAPA) cheap primer. This airplane is going to be a little on the portly side but it should have a nice finish. Around 64-65 oz I have been told that it won't matter much so we will see.
Offline frank carlisle
Re: Block coats
« Reply #1 on: June 01, 2006, 05:51:45 AM »
Sparky,
Would you please list any adjustable control features you've built into this model?
Frank Carlisle
Online RC Storick
Re: Block coats
« Reply #2 on: June 01, 2006, 04:28:36 PM »
Tip weight and leadout is all.
Re: Block coats
« Reply #3 on: June 01, 2006, 09:45:52 PM »
That's good to know.
once the flap to elevator ratio is set and the plane is built that's where it stays. where do you set that at? 1 to 1? elevator faster?
Frank Carlisle
Online RC Storick
Re: Block coats
« Reply #4 on: June 01, 2006, 10:04:53 PM »
You will find on the bigger and heaver planes it usually ends up 1-1 so I fell that if I bench trim the control surfaces there is no need for adjustable control surfaces. This is JMHO.
Re: Block coats
« Reply #5 on: June 02, 2006, 11:45:36 AM »
that's what i do except i like a little more elevator than flap
Frank Carlisle
