  • July 23, 2025, 08:40:23 AM
Author Topic: Acetate, ABS, Fuel and Glue  (Read 1400 times)
« on: December 09, 2011, 11:36:34 AM »
Acetate window material seems to be fuel proof (or at least clear bubble-pack does, and I think it's the same stuff).  And if I recall correctly, ABS plastic seems to be, too.  (Ping-pong balls, unfortunately, aren't, as I discovered this weekend after whacking up a 1/2-A plane to use one as a fuel balloon holder).
Does anyone know what glues work well at sticking acetate to acetate, and acetate to wood, without getting unstuck because of the presence of nitro fuel?  Will epoxy do it if I rough up the plastic?
Re: Acetate, ABS, Fuel and Glue
« Reply #1 on: December 09, 2011, 01:05:41 PM »
Canopy glue such as RC56  will work, it will stand up to hot fuel, and fuel for a while, you may want to coat the canopy glue with epoxy after it has dried
« Reply #2 on: December 09, 2011, 05:35:42 PM »
I looked into ABS for fuel tanks.  It appears to be soluble in nitro.  Let me know if you find out otherwise.  I have the technology to make really cool ABS tanks.
« Reply #3 on: December 09, 2011, 07:33:00 PM »
If it'll work on clear acetate, try that.
When I tested my ping-pong ball it was in a bit of clear bubble-pack; the bubble-pack wasn't marked while the ping-pong ball was well on the way to being dissolved.
« Reply #4 on: December 09, 2011, 09:11:58 PM »
Or if you rough it up and clean it well, YOu could use the slower JB Weld, I have several CF tanks that are put together with similar epoxy and they last several years. The fuel take a long time to soften the filled epoxy. I have tried high temp epoxy with ceramic powder filler and that also stands up well to fuel in raw state.
Offline Robert-Jan
« Reply #5 on: December 10, 2011, 04:14:23 PM »
If it is not too thin you can try welding it.
I did this with my ABS wind shield on my motor bike.
Greetings Robert-Jan
